Replacing DVD/RW-R drive on HP ze2000
My DVD drive is no longer functioning, so I am thinking about replacing it. Assuming I can find a replacement drive, can someone tell me how difficult it would be to swap it out? Thanks in advance...
  • 209 Answers
Very simple, just remove the casing then disconnect the wires from power supply colored yellow,black,red (connector) to dvd rom, then disconnect the cable ribbon to dvd rom unscrew the dvd to the casing then slide out the dvd rom backward( if you are facing the cpu) bfore you install the replacement, you need to check your dvd rom which you have taken out and compare the jumper orientation to your new dvd rom. if the old one is in cable select or in primary or in slave just follow the old one. now if you are finish checking the jumper orientation, you may proceed in installing your dvd rom on casing, install back the screw on bothe sides and all the connectors. power on thats it your finish just proceed to the my computer and check if this appears in it or in the device manager. i hope that this helps you, any questions or clarifications feel free to ask me.
Posted on Dec 05, 2007
I have a defective HP dvd 740 CD-Rw Drive model CGA-4166B. What model is compatable for replacement. I have a Presario SR1630NX. Thanks
Hi, Dwight.
I looked around, and I found that you can replace your cd burner drive with a dvd burner drive.
The best one that will go into your machine is a Pioneer DVD-RW DL.
It is a standard IDE/PATA drive, made for the older model computers like this one.
Pioneer DVD-RW Dl model DVR-118L
This is the same drive I have in my computer, as I have an old Dell computer, and the newer SATA type drives will not work in it.
It was fairly inexpensive, I think I only had to pay about $40 for it, and all you have to do is pull the old drive out, and plug the new one in the same way the old one is attached.
Make sure that if it has those easy drive rails on the old drive, that you take them off and replace them onto the new drive.
This will make installation alot easier.
You can buy the drive at Fry's, Best Buy, and CompUSA.
These stores still carry this model, but with technology advancing the way it does, they might not carry them much longer.
I hope this helps you out.
Good luck to you, and have a good day.
Jun 26, 2011 | Computers & Internet
My hp dv7 won't recognize any discs
Lens of the drive would have become weak. Try replacing the drive to a DVD Writer instead of repairing it.(Repairing will be a temporary solution).
Sep 11, 2010 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
Teh DVD RW drive does not work
first try clean the drive with a cleaner. then test if it works. if still not work, try replacing your DVD RW drive.
May 17, 2010 | HP m8020n PC Desktop
Can't read DVD, it only read CD-rom
try uninstalling, then re-installing the driver to see if that helps. If not, your optical drive took a dump and you will have to replace it.
Mar 21, 2010 | HP 394271-001 - HP/Compaq ze2000, ze2100,...
HP Pavilion DV 6000 laptop dvd rw will not eject sometime
the easy answer is that it's the cd or dvd, that somehow it makes the drive stuck, or it's not inserted properly. however, i'm sure you know how to insert a dvd, and that your problem is even with an empty drive.
then you have to think of something that may have gotten in there to jam the drive. paper, something from your desk. it does happen.
lastly, you're looking at hardware failure. of course, you can pop the drive out with a paperclip stuck into the little tiny hole in the plastic-- they all have them. that's not a solution, but it will get your drive open.
how are you on warranty? if you bought the unit of credit with a gold or platinum card, it may have doubled your one year warranty. you may need to replace your drive. newer laptops have a "bay" and you can just get a replacement and put it in, like replacing the battery. ask hp. I have a pavillion 6707 and i called 5 days before my 1 yr warrantee ran out, and they send a power adapter free, overnight shipping. they seem to be good about it.
let me know!
Feb 07, 2009 | HP Pavilion dv6000z Notebook
I have an internal HP DVD Writer 740b that writes on CD but not on DVD. I tried Sony DVD RW and Memorex DVD-RW to copy files on but I failed. I use Nero Essentials to burn. The dialogue box keeps saying no...
DVD-RW drives have 2 different designs, 1 used dual optics, 1 for CD one for DVD, the other uses optics that can refocus between the media types.
If you haven't done so already, flash the firmware of the drive to the latest available from HP.
Assuming that the drive worked with NERO previously, If that doesn't resolve, you will likely need to replace the drive.
If you have not used Nero with that drive for DVD media, you might try a different SW and see if Roxio/Sonic will see DVD media in the drive.
Aug 13, 2008 | HP Computers & Internet
ZV5370US Optical drive no longer works
Those chances are pretty high, although I would try testing with different discs, and types of discs. In example dvds, cd's, I don't recomend CD or DVD R RW discs though, they are generally harder for the drive to read. Also with the cost of replacement laptop parts you may consider trying to have it serviced before accepting defeat and replacing the unit.
Feb 11, 2008 | HP Pavilion zv6005us Notebook
Burner doesn't act right
If you have a backup HDD or ipod etc.. bacup your important files and re - install xp. If this dosen't work or you don't want to risk it then you might be able to just send in the DVD drive
Jan 07, 2008 | HP Pavilion ze2000 Notebook
Cant play DVD on CD-RW/DVD-ROM Combo Drive
Assuming you have tried different makes of cd or dvd disks, it's a classic drive failure problem where the laser can no longer burn or read dvd's, but may still be able to read cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
Aug 10, 2007 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
This is a problem with the DVD Writer model. SONY DVD RW AW-G170a has problems reading DVD+/- R/RW Discs. But there is no problem with any of the DVD+/- R/RW Dual Layer, DVD Ram or CD+/- R/RW Discs. It is the reason that this DVD Writer lacks the correct bitsetting for DVD+/- R/RW Discs. There is nothing else you could do other than replacing the wirter with some other model.
Aug 01, 2007 | Sony (1-796-293-13) Plug-In Module DVD...
Computers & Internet Logo
238 people viewed this question
David Payne
David Payne
