Question about Intex 4000 GPH Filter Pump
Pump will run for short period of time and then shut off
Upon investigation found that the impeller was simply plastic that in a years time is not much of an impeller as mine is completely broke at the center of the impeller and after just a short time running the outer part of the impeller is getting jammed inside their and causing the motor to overheat and shut off.
    Champion:
  • 363 Answers
Why are you running the pump wwith a defective impellar. If you continue to run this pump this way the motor might burn out, the impeller housing mi9ght crack.
Posted on Jul 28, 2009
What would cause a circulator failure?
I am going to assume the circulator pump is on a hot water circulation loop. Turning the water back on could have stirred up the sediment that has collected in the bottom of the water heater. This could clog up and possibly ruin the impeller. Running for an extended period without circulating water can overheat and damage the pump also. It is a good idea to hook a hose to the water heater drain and flush out the sediment periodically. Hope this helps.
Jan 18, 2014 | Bell & Gossett 103252LF NBF-22 Circulator...
The circulation pump on my Fluval Spec V 5 gallon quit working. I bought the tank only three months ago. Any thoughts on why it conked out in such a short time?
did it "conk" out or is the pump impeller stopped by a buildup of material ?? the reason I say this its very unusual for a aquarium pump to go completely out (ive had one running 24/7 for ten years) but in that ten years ive replaced two impellors and cleaned it out over one hundred times , and yes three months is the perfect time period for a cleaning needed !!!
Aug 11, 2013 | Fluval Spec V 5 Gallon Aquarium Kit
Lay-Z-Spa pump impeller replacement
In order to find the proper replacement you will need to provide someone with the following information.
  • amps
  • voltage
  • discharge size pipe
  • suction size pipe
Rod
US Parts Center
Jun 01, 2013 | Home
Lay z spa pump impeller replacement
Perhaps an inquiry of Lay Z Spa will yield an answer
Jun 01, 2013 | Home
Hey there my name is Ben and i'm having some problems with my well pump. Its above ground single phase rated at 220 psi (max). I recently went outside to find it running but not pumping. Having had some...
hello diesel. You are on target. It could be that the foot valve has sand in it preventing it from closing thus pumping but no water. Pulling the well will most likely be necessary. Good luck with it. Joe
Thanks for choosing Fixya!
Feb 16, 2011 | Plumbing
1hp magnum pump starts and runs but very little flow. then pump shuts down. checked for water supply and any blockage . none found in supply or return pump is about 8 or 10 years old
Sounds like a problem with the impeller, take off the lid, take out the pump basket and reach down and feel past the opening in the bottom, should feel a smooth and clean series of plastic blades, it is possible the blades a chewed up or its loaded up with hair.
Nov 22, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
Bissell 9300 will not spray liquid
I've got the 9300. Same problem occured during warranty period. They replaced the pump and it has worked fine since. The service person said never to put hot water in the tank (whish is what I was doing). If you put hot water in the tank, with the heater on, the water gets boiling hot and then the plastic impeller on the pump expands and the pump shaft simply spins and does not turn the impeller. Don't know if it is true or not, but his explanation sounded reasonable. Since then, I have used only lukewarm water in the tank and it still squirts fine (about 2 years). I also shut the heater off and squirt some fresh water in order to keep the pump cooler if I need to pause the cleaning for more than a few minutes. I took it apart one time to see what is inside. The pump is not real easy to get to. Good luck.
Mar 28, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Sishwasher not used for months. Now motor only
Disassembled dishwasher. Some plastic scraps had shredded and wound itself around the pump impeller axis. It was preventing the motor from turning. Upon removal diswasher again worked fine.
Oct 22, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Overheating problem
water pump. water pump. water pump. i am a vw dealer tech and on 2.0 and 1.8t beetles the water pump impeller is plastic, and what happens is usually another component, fans, fan control module (under battery tray), thermostat, fails and because the impeller is plastic with just one overheat the plastic becomes brittle and shatters, pull the water pump out and you will see the impeller in 3 or 4 pieces. replace water pump and make sure t stat opens, fans come on (a/c off) and proper water pump flow.
Jul 29, 2008 | 2000 Volkswagen Beetle
Abnormal noise and vibration
pump is viabrating against body remove frond base and separate metals or slip a bit of foam between
should fix problem
oterwise there may be obstuction in drain pump
Feb 23, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
Intex 4000 GPH Filter Pump Logo
347 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
