Question about Zodiac POLARIS 380 HEAD/HOSE INGROUND POOL CLEANER -
How do you take out a broken wall attachement for a pool polaris vacuum? the inside is stripped and we can't get the old plastic out to put in new plastic to attach hose to??
    Champion:
  • 363 Answers
??? is the piece your trying to remove screwed into a coupling. If so use a hacksaw blade ,insert it thru the nipple and cut very gently thru the nipple in several places. !!!!!!! I repeat that is is very importand not to damage the coupling threads. When you are cutting do it a little at a time. As not to damage the threads. If you cut to deep you will ruin the coupling. If you are not sure of what you are doing get a serviceman to do it.
Posted on Jul 28, 2009
No vacum suction
should be hooked to its own return from booster pump if pump on and filter pump on check filter on the wall fitting if ok make sure water flow from that fitting (should be in middle of pool from side to side) if pressure ok check to see if on inside if a hose came off if so put on and use zip tie to secure
Apr 18, 2014 | Polaris 180 In Ground Pool Cleaner In...
The PB4-60 doesn't fit
They changed the design of the pump a few years ago when Zodiac bought out Polaris. Re-plumbing isn't that hard to do, but if you are not comfortable with it a pool tech or handyman should be able to do it for about $60.
Feb 10, 2014 | Polaris Pb4 - 60 Booster Pump
Can't lock polaris quick connect host
check to see if both tabs are still inside wall connector if broken remove and replace if you have a rough time getting it out turn off filter and put adapter in broken fitting then try to turn out with big channel locks
Mar 18, 2013 | Polaris Pool & Spa
Polaris 3900 wheels don't turn
if good pressure at wall and filter is ok check inside to see if hoses are off or belt broken
Dec 23, 2012 | Polaris 3900 Sport Pool Cleaner ()
Polaris 380 wheels not turning
see if filter at wall fitting ok then see if water coming out of jet on back
Aug 02, 2017 | Polaris 380 In Ground Pool Cleaner
check wall fitting filter inside probably clogged and wont let water flow that's why plug blew out repair person should have caught that bad tech
Jun 24, 2012 | Polaris Pb4 - 60 Booster Pump
Machine keeps going around in circles jet at back is going straight back?
Few different things can cause this. Wheel bearings can be bad, tires worn, teeth on gears inside wheels stripped or broken, or the teeth on drive shaft worn or broken. Low pressure or clogged line can also cause to run sparatic, but not necessarily in circles. Most likely problem is with bearings, or wheels. Check these closely for problems. Most pool stores with check it and replace parts (that you purchase) for free.
Sep 21, 2010 | Polaris 380 In Ground Pool Cleaner
My Polaris 3900 sweep hose simply drags behind the vacuum. I've adjusted the sweep jet, but it doesn't appear to do anything. I'm also finding that the vacuum is gettin hung up when it gets to a the...
The hose connected on the interior of the polaris could be disconnected. seperate the housing and you will see the hose. Or you need more pressure at the wall. Try closing are reducing the amount of flow to the skimmers to up the flow at the wall connection. Your back up valve should pull the polaris off the steps. Set the rotating jet propulsion on rear to 11: 00 position.
The Pool Tech
Jun 13, 2010 | Polaris 3900 Sport Automatic Pool Cleaner ...
Cannot keep polaris attached to pool connection
Replace the wall fitting. I would bet that one of the locking ears is broken. goo luck
Aug 12, 2009 | Polaris 280 In - Ground Pool Cleaner with...
Older Polaris doesn't sweep
If the unit travels normally and picks up debris as it should,there may be a problem with a feed hose inside . Separate the haed shell and inspect. often the plastic clamps finally give out and allow hose to pop off. Also check inner hoses for any swelling and possible slits.If the unit doesn't act in a friendly way then you have water supply issues and/or inadequate water pressure to unit. Check stream from wall with unit disconnected.
Apr 06, 2009 | Polaris 380 In Ground Pool Cleaner
Zodiac POLARIS 380 HEAD/HOSE INGROUND POOL CLEANER - Logo
161 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
