I did not see any other comments, but to address the pairing issue between your Keyboard and iPad.... If your product is the actual KeyFolio Expert Multi-Angle Folio.
The KeyFolio Expert Multi Angle Folio and Keyboard uses a solid plastic frame to attach to the iPad. It's easy enough to slide the iPad in and out of the frame but the design means the case only works with the
4th and
3rd Generation iPad's
and is not compatible with the iPad 2 or the original iPad.
Connecting the KeyFolio Expert case to your iPad is a simple process. Simply hold down the power button for over five seconds to put the keyboard into pairing mode and go to the Bluetooth settings menu on your iPad to connect it. Enter the four digit numerical code on your iPad when prompted to finalise the connection.
Pulled from:
Kensington KeyFolio Expert for iPad
If you do not fall under that product, try these steps - they shuold be the same for most of Kensington's Products:
Connecting the Bluetooth keyboard to your iPad is a simple process. Simply turn it on, press the connect button in the top right corner of the keyboard and go to the Bluetooth settings menu on your iPad to connect it. The iPad will prompt you to enter a four digit code using the keyboard to finalise the connection. (the code should be 0000)
Pulled from:
Kensington KeyFolio Pro 2 for iPad
Let me know the outcome.
Jason
I’m happy to help further over the phone at
https://www.6ya.com/expert/jason_60e0f57ba319f3f6
