Whenever I try to play clips ( ie Youtube, etc) they keep stopping after a few seconds, they stop for maybe 20 seconds and they play for four seconds and stop and so on
  • 6 more comments
  • liamoc48 Jul 27, 2009
    I have done as you suggested and when I pause the clip it takes about 5 minutes to load a clip that runs for 1min 50sec. This is too slow, how can I simply click on any clip and make it run as it did up too a few weeks ago. Why does this happen?
    Regards
    Liam O Ceallaigh
  • liamoc48 Jul 28, 2009
    I have compleated a disc cleanup and Disc Defrag. How do I check the Internet speed?. I have had
    Norton Anti Virus on my PC since last year and purchased it again a few weeks ago. I did try Youtube clips again but no joy, still stopping and starting.
    Liam O Ceallaigh
    What I dont understand is that is has been working fine for the last few years and only started giving trouble in recent weeks and I have done the pause bit but I dont't really want to wait on pause for five mins to watch a clip that should only take 1 min 30sec, if the broadband was weak why is it only giving trouble now. Is there any other reason why this problem happens.
    Regards
    Liam O Ceallaigh
  • liamoc48 Jul 31, 2009
    Hello There,
    I did as you suggested and it recomended that I purchase " PC Booster" , I did try the clips again but they still freeze. Can you suggest any other ideas.
    Regards
    Liam
  • liamoc48 Aug 01, 2009
    Hello There,
    I would say the overall performance is sluggish. Windows internet Explorer is the Browser and no I have not re -installed it. Would that help?
    Regards
    Liam
  • liamoc48 Aug 02, 2009
    Hello There,
    I installed firefox and tried to play a clip from youtube and it tells me that" java script is turned off or I have an old version of Adobes Flash Player, get the lastest version" so using the highlighted tab I download the lastest version of Adobes Flash Player and tried to play a clip but I keep getting the same message. I checked the control panal to make sure that I did install the Adobe Flash Player and it is there.So now I cannot play clips at all, at least before this I was able to play them even thought they did freeze. Can you suggest somrthing that will help please.
    Thank You
    Liam O C
  • liamoc48 Aug 03, 2009
    Hello There,
    I dowloaded the Adobe Flash Player and now I am back to where I was last week with the original problem of the clips freezing. I thimk I have wasted enough time on this and will get someone in to have a look at my PC.
    Liam O C
    Hello There,
    I had already done what you suggested a few days ago but it made no difference to the clips freezing,thank you but I am not going to waste any more time on this.
    regards
    LiamO C
Hello there
I'd like to assist if I may.
The pausing instantly sounds like a connection issue. You can test your broadband speed here.
Please let me know.
Posted on Aug 03, 2009
    Brigadier General:
  • 7,191 Answers
Hi Liam,
This problem usually occurs if the internet connection is slow or the clip is larger in size. Since you have no problem with the internet connection and it is a fast connection, then maybe it is a problem at YouTube's servers.
To resolve this, you can download and install a free video accelerator tool from: http://www.videoaccelerator.com/ .
Also, you can run a free internet connection speed test at: http://www.speedtest.net/
When you open this site you'll see a yellow icon showing your location on the world map. Clicking on that icon will start the test, and you will be provided with the details of upload and download speeds.
Hope this solves your problem. For more help and clarifications , please reply to this post. Thanks.
  • 6,487 Answers
In some online video streaming you may need to buffer first the video before playing it completely, and you can also try to play it on different web browser like IE or Firefox so we can check if its happening only on a particular browser and if you also have another computer try to watch that video non a different computer so we can check if it will work fine..
Posted on Aug 01, 2009
  • Mark Gil
    Mark Gil Aug 02, 2009
    You need to download the flash player from adobe.com and then install it to your computer that should fix it...one you're done downloading it just run the software and that will fix it..
    http://get.adobe.com/flashplayer/
  • Mark Gil
  • 4,806 Answers
The reason that Youtube or any on-line video stops and starts like that is to do with your internet speed and the fact that the video is buffering.
If you look at the bottom of the Youtube video window you will see red band, pause the video and wait for that red band to fill up, the video should play smoothly after that, as the red band fills this is called "buffering".
This problem usually arises due to slow internet connection speeds or the Youtube website being at it's busiest.
Check your internet speed @ >>>>>
Regards.
Posted on Jul 28, 2009
  • 2 more comments
  • Lee Hodgson
    Lee Hodgson Jul 28, 2009
    Yes there are two main reasons after you have checked your internet speed and all is OK with that.
    The operating system maybe degrading leading to slow boot up and programs slow to load up.
    Your internet cache maybe getting to near full and needs cleaning.
    If you download Ccleaner from here and run the cleaner to clear out all you internet cache and your temp files, also use it to clean the registry and back up to the registry.
    You can download Ccleaner from here >>>>>>>>
    http://www.filehippo.com/download_cclean...
    Once you have cleaned (health checked) the computer, restart the machine and hit on Youtube again to see if the videos load quicker, if you need anymore help or advice please post back and i'll help you as much as i can.
    Remember that when you use ccleaner to clean the registry make sure you back up to the registry or the computer will not remember that you have cleaned the registry.
    Good luck.
  • Lee Hodgson
    Lee Hodgson Jul 31, 2009
    What would you say the overall performance of the computer is? i,e, have you noticed a difference with normal programs running slow and sluggish?
    Also can you tell me which internet browser you use and have you tried to reinstall the browser?
    Regards.
  • Lee Hodgson
    Lee Hodgson Aug 03, 2009
    Hi again,
    Try to reinstall your browser, if you have bookmarked any web pages make sure you back them up first, you will find the bookmarks in you documents folder called favorites.
    Before you touch IE 7/8 try a different web browser like Firefox 3.5, you can get it here >>>>>>
    http://www.mozilla.com/en-US/firefox/upg...
    Once downloaded, install Firefox and hit on youtube, if the video won't load up reinstall flash and java and try again.
  • Lee Hodgson
    let me know how you get on.
  • 4,234 Answers
This is generally a symptom of a download problem. Check your netowrk connections and verify that they are solid. The video is bufferred down to your local machine and displayed. The display is utilizing the downloaded data faster than you can load additional packets from the net. If you can not find the delay, pause the video for a little while. It will continue to load. That should allow the video to play to completion without delay. If not, then your graphics card may need an upgrade. If the card itself does not have sufficient on-board memory, the information needs to be refreshed from main computer memory which will slow things down.
Check those things first and update this with your results. There are other possibilities as well.
Thanks,
Dan
Posted on Jul 27, 2009
  • ABRsvcs Jul 28, 2009
    Thanks for the update. Lets look at the simple things first. Perform a disk cleanup and defrag the disk. The loading process can be severely slowed down by having to use many small file fragments. Verify that your internet connection still functions at speed as well. Firewall or security changes can severely slow down the internet connections. Have you changed any anti-virus settings lately? That too can impact transfer speeds.
    Check these out and update this.
    Thanks,
    Dan
When I download music from youtube with my ZTE phone, the song plays for several seconds, then stops. It then continues, and stops again. What can I do about it?
Is it possible that you have not download the whole music actually. How about giving this Leawo YouTube Downloader a try?
Leawo YouTube Downloader acts far more than a single online video downloader to download YouTube videos and other online videos from various video sharing sites like Facebook, Dailymotion, AOL, iFilm, Myspace, Dailymotion, etc. Besides the ability to download online flash videos, this FLV downloader could also acts as video download accelerator to speed up online video downloading, video accelerator to speed up video buffering for smooth playback, video player to play back videos, and IE browser to browse online videos for free downloading. It could extract audios out of online videos, like converting YouTube video to MP3. With Leawo YouTube Downloader, watching online videos offline anytime anywhere is just a piece of cake.
Hope it helps. :) Watch online videos offline freely with Leawo YouTube Downloader
Oct 26, 2016 | Audio Players & Recorders
Is having trouble reading or tracking disc.I opened top and while playing disc the tracking mechanism goes out then back in and starts playing where it stopped?
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 22, 2015 | Audio Players & Recorders
U tube videos keep stopping
If it is pausing and then playing again after a few moments, this is just a process called 'buffering'. It is allowing the player to download more of the video before it begins playing again. To eliminate this, pause the video at the beginning and wait for the red bar in the play track to fill all the way. This indicated that the video had completely loaded.
If the video will not play past a certain point, reload the page. Sometimes if a network connection refreshes during a video download, this issue will occur. If it happens continually, make sure you have a steady network connection.
Jul 04, 2011 | YouTube Videos
Everytime I play video clips on YouTube I keep having buffering problems like play then stop then play then stop then play then stop continuously.
Once the page has loaded and the video is starting to play, pause the video and let it load completely before playing. The problem is either youtube and some specific videos and/or you have a slow connection and are having difficulties with streaming content.
Feb 27, 2011 | Toshiba Satellite Pro L300 Notebook
Whenever i try to go onto youtube the video will play for a few seconds and it will keep buffring
Sorry to read about your problem, I hope this helps you out.
you just have a slow internet connection
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 20, 2010 | YouTube Videos
When i try to play a music video, it keeps stopping and a little circle goes around, then it will play for a few seconds and do it over and over
I suspect you have a very slow internet connection and you're playing high quality video, to solve this particular problem change your current speed by asking the help of your internet provider or change the quality of the video.
Sep 03, 2010 | YouTube Videos
Ps2 has to stop and reload every few seconds
Hi...
The laser lens is dirty. Gently clean it with a swab of 90% rubbing alcohol
and swab is dry with another
Apr 22, 2010 | Sony PlayStation 2 (PS2) Console
My computer suddenly stopped playing the music clips on you tube. A few will play but most will not. What happened?
since Youtube music is free and most of the songs etc. are uploaded as marketing mode. So it won' play the full list very few will play properly . So try any pay site
Feb 23, 2010 | YouTube Computers & Internet
Stop/start buffering problems when watching video clips online
no it is because of your internet speed...hope you willsucceed...
Nov 23, 2009 | Microsoft Windows Media Player
When i go on you tube or try to down load any video and play it the video skips and stops (video stops) starts again but never plays all the way through without some tpye of interuption. when the video...
hai from your mail i have understood that you are having some troubles on playing clip that is downloaded from youtube.i thing flash player 10 that you use will not be installed properly.kindly check your instalesion progress and reinstall it.hope the provided information is help full.thank you for contacting FxYa.com
Mar 21, 2009 | YouTube Videos
Computers & Internet Logo
276 people viewed this question
David Payne
David Payne
