Question about NetGear FVS318 Cable/DSL ProSafe VPN Firewall Router
PS2 is online when I test the connection, but I can't play online
I have all the cables in the correct inputs, then I go to create the configuration for playing online. I set it up. but when I go to play online i get to the point where it says authenticating DNAS infromation, but it says that my server may be down or stuff like that and to try again later, which I do but nothing happenings. It's not down though or busy, the ethernet cable is connected to the back of my PS2 and the back of my router. Someone please help.
  • 164 Answers
Try setting it for PnP
Don't forget to rank the advice!
http://www.aa1consulting.com
Posted on Jul 27, 2009
How can I connect a old PS2 to the internet
Hello rsilva,
I will help you out.
Follow these steps to connect your ps2 to the internet
  1. Turn off your ps2
  2. Grab your ethernet cable
  3. put one end of the cable into the corresponding port in the back of your ps2 (if you do not have it, it means you have the first version of the ps2 and have to buy the modem separately).
  4. connect the other end of the cable in a free port in your router (or in the port of your broadband modem)
  5. turn on your modem if it's not on already, and turn your router on as well if it wasn't on
  6. turn on ps2
  7. put in your playstation 2 network disc or a game that has internet game modes
  8. (if you choose to do it with an internet-enabled game, then go to the online section in it)
  9. create a network configuration
  10. load it
  11. create a playstation network id
  12. enjoy!
Aug 09, 2011 | Video Game Consoles & Games
How do I hook up my PS2 to the Internet?
make sure you have the Ps2 network adapter on your PS2. After that just simply connect and Ethernet cable to the back of the adapter. The other end of the cable goes to your router of course. Turn on router make sure you have a connection on your computer.( e.g. internet works) Then turn on your ps2, put in a game with online capabilities. Go to the online section of the game and create your account. And there you go, you should be connected. Keep in mind some ps2 online might not work they might of taken the servers done since PS3 is now primarily used online.
Apr 18, 2011 | Sony PlayStation 2 (PS2) Console
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
Component
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I can't play any sound from the tv (a Philips ambilight) through the sound system, despite trying every lead configuration in the manual
Make sure that you are connected to 'outputs' on the TV. Make sure that you set the sound system to the correct input that corresponds with your cable. Run a check on the sound system to make sure that the speakers are working and configured correctly using the test-tone facility.
Jul 27, 2010 | Panasonic SCBT230 Theater System
Log in problems
  1. Turn off your PS2 console.
  2. Get your CAT5 Cable (link varies based on where your router or modem is).
  3. Put one end of the cable into the port of the Network adapter (or slim PS2 and PSX) port labeled "Network".
  4. Connect the other end in a free port in your router (or on the port on your broadband modem).
  5. Turn on PS2.
  6. Turn on modem (or router).
  7. Put in online game.
  8. Go to the online section in the game.
  9. Create a network Configuration
  10. Load it
  11. Create an ID.
Jan 09, 2008 | Sony PlayStation 2 (PS2) Console
Cant get online?
  5. Turn on PS2.
  10. Load it
  11. Create an ID.
Jan 07, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 playing online madden with the network adaptor
  5. Turn on PS2.
  10. Load it
  11. Create an ID.
Jan 05, 2008 | Sony PlayStation 2 (PS2) Console
Madden NFL 08 Connection
check all the cables make sure you have everything in check or top shape this shouldnt be a problem though check the correct internet connection everything. Everything. or check to see if you have the correct cable if so then you can get a new one though you probably wouldnt want to spend money
Jan 04, 2008 | Sony PlayStation 2 (PS2) Console
Playing Online
they're phasing out the server for ps3
Aug 31, 2007 | Sony PlayStation 2 (PS2) Console
Flickering tv screen when playing playstation games.
I don't think it's a configuration problem at all. I do think that the set is not adjusting to the correct format. Most Stores have 30 day return policy. If it's over 30 days then they may not take it back. If you bought it online, then, the return may be difficult. If the return is not possible, then, contact Toshiba online and find a local Toshiba authorized servicer in your area. Hope this helps.
Mar 18, 2007 | Toshiba 15VL33B 15 in. LCD Television
NetGear FVS318 Cable/DSL ProSafe VPN Firewall Router Logo
83 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
