My display won't come on. I called customer service and they told me if they told me that if there's corrosion on the battery terminal the display will not work. Before that thermostat would read 73 degrees when set to 68 and also bat lo
  • rep1974 Jul 27, 2009
    Yes the thermostat. It has corrosion on the battery terminals.
    I am going to go get some electrical contact cleaner and see if that does the trick. But before going out the display read 73 when i set to 70 and then 77 when I changed the batteries . Then it flashed bat lo.
  • rep1974 Jul 28, 2009
    Thanks I will try this
    Top Expert:
  • Heating & Co... Master
  • 75,822 Answers
Are we talking about the thermstat here? if so replace the battery.
Posted on Jul 27, 2009
  • yadayada
    yadayada Jul 28, 2009
    use some contact cleaner and steel wool as well, get them squeaky clean, make sure the battery is fresh as well.
My battery on a 2012 Chrysler 300 had some kind of grayish blue build up on the red positive connection. Any idea why?
Your positive battery post has lost its seal with the battery case. This lets a small amount of gas to escape from the battery.
That gas causes the corrosion that you have seen on that terminal. You can get a battery terminal spray that coats the terminal in a waxy/ grease that will stop this happening.
Apr 03, 2015 | 2012 Chrysler 300S S V6 RWD
Electric start not working. When switch ignition on display lights but when depress brake and push ignition nothing happens
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and downloads that you will need please visit the websites below. Good luck and have nice a day.
What to do When Your Motorcycle Won Start
Steps to Take When Your Motorcycle Won Start Dennis Kirk Powersports Blog
http://absolutelyscooters.net/service-manuals.html
CPI Scooter Parts Racing Planet USA
Free CPI Motorcycle Service Manuals for download
May 24, 2013 | 2007 Cpi Aragon GP
My battery fell out of my phone I tried turning it on but it seems the end button doesnt work. I tried plugging it in but it goes to the charging screen but won't turn all the way on please help!
Hi,here are the basic steps to check your phone problem.
* Try another battery to check if that's the only problem,
* also try another battery if there's a response in charging.
* check the battery terminal if there's a corrosion as well as the battery interface, re-align battery terminal pins if its leveled.
* if nothing the above works,consult a mobile service center for assistance.
thank you for visiting fixya.
Jun 16, 2011 | LG Cell Phones
1990 plymouth colt, new alternator, still won,t charge. what tells alternator to charge battery?
Have you also had the battery checked? If the battery is bad, then it won't charge. All of the terminals need to be checked for corrosion. All wires must be secured properly. Check to see if the ground cable is properly attached to the frame of the vehicle.
May 03, 2011 | Ovens
Donotswitchingon
How to Troubleshoot a Cell Phone
Cellular phones don't always function as perfectly as you might wish. This chart offers some solutions for common problems with these devices. If you don't find an answer here, bring your phone to an authorized cell-phone center. Avoid taking apart the phone, because this will void most warranties.
Instructions
Technical Difficulties
If the phone doesn't turn on, make sure battery is charged and fully plugged into phone. Remove battery from phone and use rag to brush away dirt that may interfere with connection. Reconnect and try again. If using cigarette-lighter adapter, make sure it's properly plugged in. Make sure charger is properly plugged into outlet and into battery.
When the battery doesn't charge, plug lamp or other electrical device into outlet to verify that outlet works. Borrow friend's charger to see if charger or battery is problem. Replace charger or battery if necessary.
In case the phone gets wet, remove the battery from the phone and allow both to dry thoroughly. If rust or corrosion develops, wipe it off with a stiff brush. If phone still does not work, replace it.
Should the display not be working, try getting it to room temperature, extremely cold or warm conditions may affect display functions.
If the keys don't work, look for a display of a symbol that looks like a lock. the keypad may be locked. The display often tells you how to unlock it. If not, check owner's manual.
Problems While Talking
During times of bad reception, make sure antenna is up, check to see if the battery is low. If you're indoors, move toward window or go outside to get better reception. Remember that tunnels, basements and elevators interfere with cellphone reception. In case of storm, wait for it to subside. Contact your service provider if you have chronic static; phone may be defective.
If you can't hear the other person, make sure the volume is not turned down entirely.
Check that antenna is up if you get interference from another call. Change locations for better reception or switch to a digital phone.
When you experience many dropped calls, check the battery. It may be low. If you constantly lose calls, consider switching to provider with better coverage and/or to digital phone. Providers that offer digital service combined with analog tend to have better coverage.
Dialing Issues
If you can't dial out, try again. The network may be full. Change locations to get a better signal. If the display says "No SVC" or "No Service," you are in area with no service. Wait until you enter area with service. Check to see if battery is low. If you are outside the service area, contact customer service (try 611 on cell phone). Some service areas require PIN numbers to protect against fraud.
If you can't receive calls, confirm that neither call forwarding nor automatic voice-mail pickup is activated. Make sure ringer volume is turned up. Confirm that ringer is on (not in silent mode). Change locations for better reception. If display says "No SVC" or "No Service," you are in area with no service. Wait until you enter area with service. Call customer service. You may have restrictions on incoming calls.
If you can't make long-distance calls, call your service provider (try 611 on cell phone). You may be out of calling range and/or may need PIN number to dial long-distance numbers.
When problems occur with your service provider, call customer service to register complaint .
hope it helped'
Thanks for using fixya.......
Jan 17, 2011 | Cell Phones
The display all the sudden stopped working on my elyptical proform C630. Is it a battery I need to replace
Most likely. Remove and re-insert your battery, checking for signs of corrosion on the battery and battery terminals. If corrosion is noted on the terminals, you can remove it with an emery board or fine sandpaper. This may correct the problem, otherwise changing the battery will probably solve the problem.
Best regards,
--W/D--
Jan 13, 2011 | Sport & Outdoor - Others
My HHR is having a hard time trying to start. When I turn it back to off and then back to on it starts then. Someone told me it was the battery, but the battery light is not on, the motor light is on.???
also check your battery connections for corrosion they may look clean but inside the ring terminal & the battery terminal gets heat corrosion also if possible check the water level off the battery
Jun 05, 2009 | 2006 Chevrolet HHR
My C875 Kodak Camera does not display anything when switched on, but as soon as i connect USB code, it displays properly, when removed, goes back to same problem
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Mar 27, 2009 | Kodak EasyShare C875 Digital Camera
Continuous Limited Service display
i have the same phone and which has the same problem i rang customer service to see if they could help they told me to try my simcard in a different phone and the sim works no problemwithsim they told me it could be the phone that is broke only had the phone 3 month
Oct 01, 2007 | Samsung SGH-D900 Cellular Phone
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
