I appreciate your inquiry, Ape!
From what you have described your Electrolux dryer is displaying an error code of "E75". An"E75" error code is not showing as a valid error code it could be a possible miscommunication with the control panel and I would recommend performing a reset on your dryer. You can do that by disconnecting the power from it for ten minutes. Could you please provide me with your model number? You can normally locate the model number on the serial tag which is located on the door frame. Also, once you reset it can you provide feedback if you continue to receive that error code. Good luck. -Matt
