Question about Coleman Powermate Powermate 5000W Generator
I have a coleman powermate generator 5000 in from 2006. Has never been started. I tried to start, filled the oil/gasoline and It would not start. What can I do beside's taking it in for service.
  • vazquez730 Jul 28, 2009
    Yes to the choke. How do you prime the carburator?
  • 57 Answers
Remove the air cleaner and spray some starting fluid into the carb. If it starts then ok if not then remove the spark plug and check for spark.
Keep posting until its fixed. Give the model number PMxxxxxx.
Posted on Jul 30, 2009
    Champion:
  • 363 Answers
Did you apply the choke, did you prime the carburator
Posted on Jul 28, 2009
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
WILL NOT TURN OVER OIL FILL A PULL START
Sounds like you may have oil in the cylinder. This is caused by engine tipping over or maybe the generator fell over on its side, etc. This ends up making it really hard to pull start the engine.
Anyway, try removing the spark plug (make sure the ignition wire is pulled out of the way) and then turn over the engine a few times (5 or 6 times) to get any oil out.
Then replace the spark plug and try again to see if it starts.
Mar 15, 2011 | Coleman Powermate Powermate 5000W...
What's the best choke setting for starting a cold generator
Full choke to start, open choke partially immediately the engine starts to where the motor runs smoothly, continue opening as soon as you can while keeping the engine running smoothly. Be sure to open fully before leaving the unit, running it with the choke partially on can cause a rich fuel condition which tends to wash the oil off the cylinder walls and it also dilutes the oil with gasoline.
lp
Dec 26, 2010 | Coleman Powermate Portable Generator...
Wont start
when you added fuel to the old fuel in the tank, i advice you to take all the fuel out, clean the carb, blow out fuelrestrictors in it and fill up with new fuel and try again. also check the sparkplug, and check if it sparks. good luck.
Feb 13, 2010 | Coleman Powermate Powermate 5000W...
9hp briggs and stratton engine has gasoline in the engine oil
Old gas, gone bad from sitting. Drain all gas out and use carb cleaner in unit to clean. Add fresh gas.
Oct 01, 2009 | Coleman Powermate Powermate 5000W...
Can't start coleman powermate 500 generator
I had one of these and it was very sensitive about getting the carb jet plugged up from leaving gasoline in the tank and carb bowl. I had to take it apart and clean it w/ card claener several times. I can tell you the engine is super sensitive ab out the needle jet setting. Too rich or too lean and it won't run at all or will gas you out from the smoke.
Jul 27, 2009 | Coleman Powermate Powermate 5000W...
Coleman powermate 3750 watt brand new I started it
Check the oil level & try again to start many times until it became loose because the engine became stock up for long time not use.
Mar 12, 2009 | Coleman Powermate Powermate 5000W...
Oil for Coleman Powermate 5000 PM0545305.03
Yes, SAE5W30 is just the right oil for this machine,it will take about a quart to fill it up to the bottom of the threads in the oil fill hole.
The engine of this generator is essentially just like a lawn mower with a fixed throttle setting. You should expect all of the same issues as any small engine that's been sitting for a while. Check the fuel tank for water/debris, check the carb for fouling, check the spark plug, etc.
If the generator has been sitting for 3+ years without running you may need to flash it to get any voltage out of it. If you get the engine running and it won't make any electricity ask me directly and I'll talk you thru the procedure.
I looked on www.powermate.com for an owners manual but they only seem to have the parts list, rats.
Regards,
Carl
Dec 13, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
568 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
