Question about Garden
When been running and get hot enigne chocks its self out and there is oil in air filter and carborator
  • 30 Answers
Check the positive crankcase ventelation or maybe excess blowby from the rings is causing oil to be pumped into air cleaner.
Posted on Jul 28, 2009
My TB575EC weed eater will not start. It seems oil is some how getting into the air filter
The rings on the piston are passing too much oil/gas mixture due to the lost compression. Or, you have incorrectly mixed the oil and gas, if it uses a mixed fuel.
Sep 02, 2016 | Troy-Bilt 29cc 4-Cycle Straight-Shaft Gas...
My mower was running fine it started to lose power and run about half throttle now it want run put chock on it run a second then quits
Hi Bobby:
I'd probably tend to give it a maintenance "once over"
- Change plug(s)
- change oil (and filter)
- flush carb (check fuel filter)
- fresh gas
- clean air filter
- clean underside of mower deck
See how it runs and we'll help with any remaining problems.
May 13, 2015 | Garden
Motor runs but cart won't go
1 check and clean fuel tank and lines
2 clear air filter, soapy water air dry then apply any air cleaner oil
3 adjust carb / chock
4 check for proper spark replace plug (2.99 )
5 make sure drive belt in good working order.
odds are the carb chock should fix you right up
May 23, 2014 | Yamaha G1 G-1 2-cycle Gas Golf Cart Tune...
Oil/chock light comes on at idle of when i excelerate
do an engine flush then refill with a 20/40 oil .as you have very thin oil.or lot of dirt on the oil pump and the sensors..so get an engine flush run it till hot then drain .and change the oil filter and your 20/40 oil.check both amount needed and the level do not over fill
Dec 21, 2013 | 1983 Oldsmobile Cutlass Supreme
Oil came out of air filter
check your Turbo Charger.....looks like leak from Inlet side
Sep 02, 2012 | Electrical Supplies
Hi, I have a craftsman walk behind lawn mower that has run great for about 7 years or so. I have done nothing to it but change the oil. The last two times I took it out it ran great for about 30...
Since you said that the only thing you have done for seven years is change oil, then definitely change the air filter and the spark plug. As for the indications of overheating, if not resolved by changing the air filter (plugged air filter acts like a choke and the engine runs richer), then inspect under the shoud and make sure that you do not have any grass buildup anywhere especially around any cooling fins. Changing the air filter and the plug after all this time will probably boost your fuel efficiency also.
Sep 09, 2011 | Craftsman Garden
Lawn tractor lost power while in use engine slowed down
Check for spark, if spark is present, then remove air cleaner and pour some gas down carb. not to much, then keep away while starting. If motor starts and runs then shuts off you have a stuck needle and seat or fuel pump problem.Also check oil level.
Mar 06, 2010 | Craftsman Garden
Where do you locate oil filter on a 2003 mercedes c180
KOMPRESSOR ENIGNE?? IF SO CHECK BY THE FIREWALL DRIVERSIDE. ITS A THIN FILTER CAP , HAS A BLK 27MM PLASTIC ALMOST NUT TO REMOVE OIL FILTER.
Apr 10, 2009 | 2003 Mercedes-Benz C-Class
Self oiling air filter
great bike but it pisses oil into the air box. Ends up with the luxury of a self oiling chain and a huge mess on the side of the bike. This has been happening since new. Am I putting too much oil in the tank should I only check oil when hot to allow for expansion or is this one of those crappy little problems with this motor that I will just have to live with?aways check oil when it warm and don't overfill it. make sure the air filter stays clean. if the crank's vented to the air box a dirty air filter will allow the crank oil to be pulled into the airbox.,,
Nov 10, 2008 | 2006 Gas Gas Pampera 400
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
