HI, I have a Kenmore Elite 4586/87 washer. I am getting the error code Fdl. I have replaced the door lock mechanism, but am still getting the error code. Some times the washer works sometimes it doesn't. Any ideas?
  • tim389 Jul 27, 2009
    I have checked the connections to the ccu.
    How hard is it to replace the door lock switch, if that is possibly the problem?
  • 15,935 Answers
F DL
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes / Procedure
■ Door lock mechanism is broken or removed from door.
■ Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
If there is not another error (F11) the door lock is the problem. An F11 in combination with the FDL error means the controller is bad.
Many times an uneven load or multiple unbalanced loads will cause enough vibration for the door lock plug to be unseated enough not to make contact.
First remove the top of the machine. This is done by pushing it back slightly, about 1/2 inch, so that the tabs come unhooked, and then lift it off. Near the back of the machine on the right hand side is where all of the wiring hooks into the computer portion that controls the door lock (and other things) is located. The pink wires control the door lock. They are inserted and removed in a manner similar to a phone jack.
Here's the solution: Make sure the wires are all inserted tightly; with all of the jarring during the cycles, they sometimes loosen. take the connection out, look at it and put it back in. While you're in there - check the connections on the other end of the wires.
Now cross your fingers and re-try.
Many repairmen will tell you to replace the board - however this is a simple check to do before spending $230 on the board plus labor.
Thanks for using FixYa!!
Please accept this answer to remove it from the work queue.
:D
Posted on Jul 28, 2009
  • 346 Answers
The "F/dL" will display when the door fails to lock. A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error. Potential causes:
  • Door lock mechanism is broken (which you have replaced)
  • Loose wire connection between the door lock mechanism and the Central Control Unit (CCU). This is most likely your problem.
  • Door lock/switch has failed.
I recommend calling a service technician to diagnose and repair your washer. The likely failure is the door lock assembly.
Good luck.
Posted on Jul 27, 2009
  • Joy Shannon
    Joy Shannon Jul 28, 2009
    I'm sorry but I can't answer that question. If you have checked all the connections and replaced the door plus ruled out the other problems that it could be (see my solution post) then I don't know what else to tell you except to have a professional look into it. It looks like you have done all you can. I hope you can find the help with this that you need. I know having a appliance only half working is a real drag. Good luck.
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
GIVING CODE FDL?
If the door fails to lock after six (6) attempts "Fdl" will display. The "Fdl" error code indicates the door failed to lock or the control does not detect the door being locked. The likely failure is the door lock mechanism. There is always a chance there could be a loose wire connection between the door lock mechanism and the Central Control Unit (CCU) causing the error too.
Jan 22, 2011 | Kenmore Elite 45986 Front Load Washer
What does code FDL mean? kenmore elite wash maching
You are getting and error code F-DL which means the main control board is sensing that the door is not locking. Most likely a problem with the door lock/latch assembly.
Feb 02, 2010 | Kenmore 45981 Washer
FDL fault code on kenmore elite washer
F DL
Nov 08, 2009 | Kenmore Elite 45986 Front Load Washer
Error code dL F is popping up on washer. Door will not open, is locked but light will not come on on panel where is says "door locked." Can't wash, nor get the clothes out that need to be washed.
Fdl is a code that indicates a door lock error. This error occurs because the washer senses that the door cannot be locked (even if it is). The door will try to lock six times before displaying the error code. You have a faulty door lock switch. Hope this helped and best wishes.
Sep 01, 2009 | Kenmore Elite HE4 Electric Dryer
My kenmore elite smartwash flashes f and dl when i try and run the wash cycle
Hi
Thanks for using FixYa. Error fdl means a Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
It has occurred due to
1. Door lock mechanism is broken or removed from door.
2. Door switch/lock unit failure. To unlock it follow the steps—
a. Unplug washer or disconnect power.
b. Check door switch/lock unit.
c. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Please revert for further assistance.
Thanks
Rylee
Jul 21, 2009 | Kenmore Elite 45986 Front Load Washer
F dL code message
Hi, this is a failed door lock alert. the FdL code represents this malfunction in the door lock mechanism. the unit will not operate if the door lock cant engage the latch. replace the door lock mechanism asap. this will fix the issue.
Jun 05, 2009 | Kenmore Elite 45986 Front Load Washer
DL F signal
Hi, this is a failed door lock alert. the FdL code represents this malfunction in the door lock mechanism. the unit will not operate if the door lock cant engage the latch. replacing the door lock mech will fix this issue.
I have a Kenmore Elite Quiet Pak 4 HE3T Washer. The door is locked with clothes in it. The displays is saying F dL. What has happened and how can we open the door.
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
• Door lock mechanism is broken or removed from door.
• Door switch/lock unit failure.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Apr 12, 2009 | Washing Machines
Kenmore elite he3 - door lock
If sound like a lid switch issue. Open the top of the washer to get an access to the lid switch(located near the doorframe). Look for a loose wire or a broken switch. In case there is no loose wire or broken switch, you should replace the switch. Good luck!
Sep 05, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
