most watches with one knob have a duel action on that knob
the first click is the date section , pull it out a bit further to a second click and that is the hands movement
when set to right date and time push the knob all the way back in
If it is this pocket watch, then the crown (the bit you turn to wind the watch) has 3 positions. Position 1 is when the crown is pushed in all the way. Position 3 is when the crown is pulled out as far as it will go. In between position 1 and position 3 is a place where the crown will stop, this is position 2. To set the day of the week, pull the crown out to position 3 to set the time. When you set the time, the bottom dial with also turn to set the hour on the 24 hour clock, if you turn the crown enough to cycle through a whole day the day of the week dial will also turn. Keep turning the crown until the time is set on the proper day of the week. To set the date, pull the crown out to position 2, and turn it clockwise until the hand on the date dial points to the correct date. Hope this helps!
most of the time with watches, there are two "pulls" on the stem to set the date and the time. normally, when you pull it out all the way, that's the setting for the time. so i think you've pulled it all the way out. try pushing it back in, then give the stem a soft pull. you'll feel about halfway, it stops a little bit. that should be the setting for the date. i hope this helps
This watch should have a "quick set" date function that lets you advance the dates by turning the setting crown. To get the watch in this mode, pull the set stem out half-way. At that point, turning the setting crown will advance the date on the watch without turning the hands. One some watches, finding the right position for the set stem can be a bit tricky--either it's not out far enough or it's out just a bit too far and the time hands turn. You may have to try pulling the stem in and out a few times to get it just right.
A word of advice: watches are generally designed to advance the date, not to turn it back. It's suggested that if you need turn the date back, you actually advance the date wheel up to 30 days to get to the date you want. Some watches do permit you to turn dates backwards, but I prefer not to risk the chance of hanging up the little springs and mechanism that are designed to advance the date indicator.
One final note: I have serviced several Timex mid-size (ladies or kids size) Expedition watches that lack a quick-set date. Many Timex watches in that size do have a quickset date like I've just described to you, so I have no idea whether these watches happen to have a cheaper movement or if they have some internal damage (it's been the same model each time). At any rate, for those watches, I have had to use the incredibly slow and painful process of advancing the time 24 hours to advance the date. With those watches, if the date is too far advanced by a day or two, it may be easier to stop the watch for 24-48 hours until the date is correct, rather than spend a huge amount of time spinning the crown to advance the time. Hopefully, your watch will have the more sophisticated movement, though.
mcdevito75 here, If your Timex has a Stem (winder) do this, Slip a fingernail just under the stem and gently lift the crown just a bit, the stem has 2 positions, it may take practice so be patient, once the crown is in it"s first position you"ll be able to change the DATE, set the date 1 date before the date you want so that the date will change on time at about Midnite. Now with the date 1 date before the date you want, push the crown back in and pull the crown out to set the hands, go thru the 24 hour cycle once till you reach the date you want, set also the time of day and your done. Hope this helps.
To s e t t h e t i m e a n d d a t e Your TAG Heuer chronograph is fitted with a screw-in crown and safety seals which guarantee it to be waterproof to 200 m (660 ft). Position 0: Crown is screwed in (normal position). Important: The crown must be screwed in correctly to guarantee the water-resistance of the watch. Position 1: Crown unscrewed. To change the hour (change of time zone) or date quickly, unscrew the crown, pull it out to position 2 (quick corrector) and turn it in either direction. This mode allows you to change the hour and the date without any loss of minutes. The date changes each time the hour-hand passes midnight. To set the time, unscrew the crown, pull it out to position 3 (setting the time) and turn it in either direction. After setting the date or the time, push the crown back and screw in to position 0.
Some TAG models have a date "quick set". Pull crown out just a wee bit to position #1. Turn counter clockwise to advance date. Pulling out the crown to position #2 stops the watch and sets the time.
