Question about Boating
Lowrance X-16 Rollers
I have a Lowrance X-16 that I need to replace the belt rollers on because they have become soft and mushy. Does anyone know where I can order parts for this fish finder?
Where are you located? Would I be purchasing this from the Sheriff's Dept.? I live in Keller, Tx 76248 in the Ft. Worth Metro. Any idea on shipping cost?
Posted on Sep 25, 2016
2 Suggested Answers
SOURCE: I NEED REPLACEMENT ROLLERS ON MY LOWRANCE X16
We have a x-16 that hasn't got 10 hour total on it. It was used on Sheriff Dept rescue boat and has been storage since late 80's. 25.00 and you pay shipping buys the unit and a case of paper for it. It doesn't have the power cord or transducer with it. That was misplaced years ago.
Posted on May 14, 2009
I have put a new belt on my einhell belt sander I've adjusted it as advised but the belt still moves to the right
The two rollers need to be perfectly aligned and parallel to each other for the belt to rotate correctly.
Remove the belt again and check the two rollers to make sure that there is nothing stuck to them that would cause the belt to run off to the right. A piece of tape is enough to make one side of the roller a larger circumference which enhance the taper effect.
Now check the belt in case something has become stuck on the back of the belt that would cause the belt to run off to the right. Something like tape stuck to the back of the belt will decrease the internal circumference of the belt on one side and make the belt run off.
Finally, you may have to replace the bearings on the rollers as they may have become worn. You may want a power tool engineer to do this for you.
May 24, 2015 | Sander Tools & Hardware - Others
I have a 1997 Jimmy,I need to replace the window rollers,does anyone know if the replacement rollers replace the riveted ones that are stock? And do they just bolt on where the original ones are and then...
I have same problem, just ordered rollers , they look alike as old riveted rollers and there is a nut on the other side. Do you know hot to replace them?
Jan 27, 2011 | 1997 GMC Jimmy
Clothes getting stuck in front of dryer the model wasn't listed below mode is LDE8404ACE
If your clothes are getting stuck in the front of the dryer, it could mean more than one thing.
Your front felt seal is faulty, broken, or out of position.
After years of use, the front felt seal on the dryers break down,come loose, or become faulty. It is also sometimes caused by wear in the drum rollers, and this causes the felt seal to become worn.
You will need to replace the front felt seal and possibly the drum rollers.
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum, felt seal and belt. It is a good time to check and replace the felt seal. You could stop there but I recommend that you do the following:
Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots, if they are worn or have flat spots on them replace them.
If the drum rollers don't have flat spots on them and is not worn, then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 14, 2009 | Maytag PYE2300AY Electric Dryer
I need to know how to replace...
The transfer belt cleanning blade is under the transfer belt.Remove 2 screw and change it.The bias transfer roller is mounted in two bushings,remove the bushings and 2 springs.The fuser unit : upper fuser roller,lower fuser roller and the cleaning rollers.
Aug 25, 2009 | Office Equipment & Supplies
I have an Amana ALE643RBW drum needs manual assistance to tumble
If you remove the back panel you will be able see the drum rollers. There's a good chance they may be worn out. As long as you are replacing the rollers I would suggest replacing the belt at the same time.
Typically when the rollers wear out, the drum drops ever so slightly and the drum wears on the front and rear drum to cabinet seals.The added drag can cause a slow drum and squealing noises.
Good luck, let me know if there is anything further you need.
Regards,
Aug 18, 2009 | Amana ALE643RB Electric Dryer
Noise
You may have something caught in the rear felt or you may have a bad drum roller. Inspect the inside of the drum at the rear to see if there is anything stuck in the rear felt. Also check the front felt. If nothing is there you probably need a set of rollers part number 349241t. To replace the rollers, first remove the lint screen. Then remove the two screws under the screen (phillips). Swing the top back, it is hinged, and then remove the two 5/16" screws that hold the front in place. Swing the front out of the way being mindful of the wires going to the door switch. Now disengage the belt from the motor pulley and pull the entire drum out of the machine. You will see the rollers at the rear. They are removed by pulling off the traingular plastic retainer. Before you replace the rollers clean the shafts with emery cloth and give them a short spray with wd-40. Wipe the shafts clean and replace the rollers. You should inspect the belt (p/n 341241) and the idler pulley (p/n 691366) and replace them if they are worn.
Apr 08, 2009 | Whirlpool LER8648P Electric Dryer
Craftsman 3x21 plastic front roller needs replacing
Do you know anyone with a metal lathe or that works in a machine shop? If you do ask them if they can make the rollers for you out of metal. Or else find a machine shop and ask them to make you new rollers.
Apr 01, 2009 | Tools & Hardware - Others
Vertical line on copies
A vertical line on laser copiers which are the same lenght apart on each indicates a dirty or defective toner cartridge or dirty or defective rollers. Take the cartridge out and wipe the rollers with a soft cloth. If the streaks continue then the rollers inside the cartridge or damaged. You will need to replace the toner cartridge. Let me know if you have any questions. Please rate this solution with 4 diamonds.
Mar 29, 2009 | Dell 3010cn Laser Printer
Mar 26, 2009 | Boating
Document jams ep 4000
Ceck the rubber rollers on the doc feeder. They are probably real soft and mushy. If so they need to be replaced!
Dec 14, 2007 | Minolta EP4000/5000 CS/PRO Copier
Boating Logo
338 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
