SOURCE: Sony KLV-32M1 LCD TV switches off/on
Check capacitors and soldering around power supply and inverter.
You can download service manual from elektrotanya:
http://elektrotanya.podzone.net/?q=showresult&megnev=sony&megnev2=KLV-32M1&kategoria=&kat2=schematics
SOURCE: SONY KLV-40U100M LCD TV will not power up. looking
by going to people that are true helpers and not looking for the almighty dollar...............
Testimonial: "I believe !!!!!!!!!!!!!1"
SOURCE: my sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
SOURCE: 8 blinks from a sony bravia model klv-32s400a tv
8 blinks in KLV-32S400A shows Audio Error
Check audio voltage supply from power supply board, if OK, replace GP Board (main board)
and if audio volts are not available, check/ replace power supply board.
SOURCE: looking for a sony bravia klv-46x350a lcd spare
Usually the LCD panel cost is around 80% of total TV price. Look for it in a center of service.
