Question about Panasonic PT-61G54 61" Rear Projection Television
No color on my T.V., before when the T.V. would warm up it eventually came back. Now there is no color except when you press the Menu button the Menu showes color. What is the problem and what can we do to fix it Please Advise....The Counts Family
  • 280 Answers
Re: No color on my T.V., before when the T.V. would warm...
Sounds like the signal board may have a problemn OR If the signal to the set is low it could lose color burst. If you are using a cable box .. try removing it and hook the cable direct to the TV and see if any change. If the set works ok without the cable box that box may be the problem.
Posted on Jun 20, 2008
0 characters
3 Points
My jvc is showing black and white what do i do
Just reset the picture adjustments and se whether the colour comes up or not. If not, autotune it once more.
Reset resets all picture adjustments (tint, color, picture, bright, detail, color temperature, dig.
noise clear, Color Management and Dynamic Gamma) at once to the default settings.
Press the MENU button
Use [up-down-prog up-prog dn buttons] To enter
The onscreen menu disappears for a moment,
and then the settings are reset to the default
setting for all the picture adjustments.
Press the MENU button when finished
To autotune
Up or Down button To operate
To choose CABLE or AIR
Press the OK button to start
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen
Mar 21, 2011 | JVC HD-61Z575 61" Rear Projection...
We have a Phillips plasma tv and the picture pixelates randomly and freezes for about a second and sound breaks also. We have had everything checked and have been unable to find a solution. The latest...
In my openion, Its problem of hardware in your TV and signal processing circuits are involved. It might be problem of Firmware (programe to control the performence over all) Philips can advise you better in this regard.
Aug 01, 2008 | Projection Televisions
My Sony KP-57WS500 TV has curved horizontal white lines. You only see them when there is something dark on the screen. Any ideas?
You have 3 CRTs inside of your TV that create image. Blue, Green and Red. Looks like one of them need adjustment due aging.
Remove front grille. Than remove center "shielding" piece held by 4-5 screws. Behind this cover you will find little black plastic box that have 6 rotating buttons on it. Take you time to study them. There is three columns and two rows. Columns represent color, rows - "Focus" or "Screen". You need to locate "Screen" row of three rotating buttons. They will be marked "B', "G", and "R" for colors accordingly. Turn on TV let it warm up and try to figure out witch color is dominating others on your screen. Then carefully turn rotating adjuster counterclockwise using Philips screwdriver. Try to muscle-remember original position of screwdriver so you can turn it back to it.
Eventually you will find the right one, you will see lines dissapear when you reduce voltage and reappear when you turn rotating shaft back. Sometimes more than one have to be adjusted.
Try to have all three color to be present and visible but with no over saturating and no horizontal lines.
Put cover and grill back - and that's should do it!
Apr 06, 2010 | Sony KP-57WS500 57" Rear Projection...
How do i adjust color screen is bright need to darken
You can adjust brightness by following these simple steps:
1) Press the MENU/SELECT button on the remote to show the on screen menu.
2) Press the CURSOR RING RIGHT to enter the PICTURE sub menu.
3) Press the CURSOR RING DOWN repeatedly until the EYE FIDELITY control is highlighted.
4) Press the CURSOR RING RIGHT or LEFT until you select the option you want, either PROGRESSIVE or INTERLACED.
5) Press the STATUS/EXIT button to turn the menu off.
Helpful Hint
- The Eye Fidelity control is not available for use with AV4 and AV5.
- You may want to use the interlaced option to enhance programs containing a lot of motion.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
Apr 04, 2010 | Philips 60PP9352 60" Rear Projection...
How do i reset my television back its original color
Press the remote button said menu on the remote.Go to colors setting,go down to reset press that answer yes colors well reset to the original setting.
Jan 05, 2010 | Projection Televisions
The sound went out on my jvc hidef tv
Reset- resets all picture adjustments (tint, color, picture, bright, detail, color temperature, dig.
arrow To RESET
arrow To enter
setting for all the picture/audio adjustments.
Here is a LINK to download your owners manual
Feb 12, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Yellow and blue color ruins total picture on 50" tv,can't get rid
I'm no expert, but I think that you have a problem with the convergence of the 3 color guns. I've been working on a similar problem. As a first step, have you tried "Magic Focus?" The Magic Focus button for the Hitachi 53UDX10B is at the left of the small front panel controls that also include your RCA composite and SVideo connectors. Let the set warm up for about 20 minutes (as recommended by the user guide), and then press the Magic Focus button. When you press the Magic focus button, the set will auto align the 3 color guns. If this doesn't fix your problem, unplug the TV for at least 4 hours and try again.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
LG 52SX4D-UB color problem
After numerous hours of searching the internet and purchasing a new color wheel I found the real problem. If you replace a color wheel or even the lamp you need to be able to get into the Service Menu. This is something that the repair technicians don't want you to know. With the tv that I have the original owner was told by a repair tech that it would cost about $800.00 to repair. After the tech left the problem was worse than before he got there. After getting into the Service Menu I found that the Contrast was cranked up to 115% and the color wheel setting were way ! way !! out of adjustment. This sounds to me like a repair person trying to make some fast money. I am posting this proceedure so that others will not have to go through what I and the original owner have gone through. Also here is a link to the site that I found this information. They are a good reasonable site for a soure of parts.
Instructions for resetting counter:
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
5. Press and hold the ENTER (or OK) button on the TV front panel.
6. While holding that button, press and hold the MUTE button on the remote.
7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
8. Release the MUTE button first, then the ENTER button on the TV front panel.
9. Make a note of the lamp hours if you want.
10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
11. It will ask you to confirm the reset--press SELECT again to confirm.
To verify you've reset the hours, you can repeat steps 1-9 above and then just press the EXIT button on your remote.
Jul 22, 2008 | Projection Televisions
2yr old DLP TV flashes for few mins then has red tinge
Push the menu button when the problem shows up again. Please tell me if the flashes show up in the displays as well on the menus. I can take it from there.
Apr 15, 2008 | Mitsubishi WD-62927 62" HDTV
Panasonic PT-61G54 61" Rear Projection Television Logo
47 people viewed this question
Top Panasonic Projection Televisions Experts
Jaime Hernandez
Josh Whitehead
Josh Whitehead
Are you a Panasonic Projection Television Expert? Answer questions, earn points and help others
