I have a new Mitsubushi 18,000 BTU Mr. Slim ceiling mounted (SEER 13.2) Comfort System. It is for one room only sized 20' by 20' by 12 ' high. The room is on the second floor, has no windows and is insulated on all sides. Like other posts I have seen, the Mr. Slim generally cools the room (even at 100 degree outside days in Texas) to 75 degrees or lower but the humidity immediately goes up within the first 1 to 2 hours to 60 to 70% relative humidity. I have complained and Mitsubishi authorized a new unit to be installed and it was installed. The new unit still is producing humidity at 60 to 70% humidity. Is this an inherent defect in this design? Any solutions? Why doesn't using a Trane conventional air conditioner unit result in this same high humidity problem? or could it?
  • ccotropia Jul 30, 2009
    I appreciate the last posted advice (to reduce the fan speed and install a dehumidifier) but wonder if there is any way that the current Mitsubishi can or should be able to keept the humidity at 50% or less. I have run the unit on its lowest fan speed but still have the same issue. The room humidity is around 45% when the unit is first turned on and then it rises to 60-64%. I understand this will occur as the room cools down but I would hope a properly desiged A/C unit would keep the humidity in check. My other Trane units (SEER 19 and 6 ton units) don't create this same problem. The humidity stays at 48 - 50%. Is this just an inherent issue with this Mitsubishi unit that I will have to live with unless I install a dehumidifier?
  • 15,935 Answers
A/C units do not remove all humidity - that is the purpose of a de-humidifier. Instead they STABILIZE the humidity in the form of condensation when the hot refrigerant is misted into cool vapor. The humidity condensate collects on the coils... thereby stabilizing the humidity at a certain temperature.
There is a drainpipe, usually a white plastic pipe, coming out of your unit that should be dripping water this time of the year at a pretty good volume. This water is the moisture from your house. If it isn't able to discharge this water when your air conditioner is running, it will continually put it back into your home, increasing the humidity level.
Check to make sure the tube is clear and the unit is properly draining.
Thanks :D
Posted on Jul 30, 2009
  • blueextc3221
    blueextc3221 Aug 06, 2009
    This follow-up contact letter is in regards to the problem you submitted to FixYa.
    Please return to your account and accept my solution If it best answered your problem -
    As unrated questions older than 7 days are credited to the first expert that attempted to answer your question...
    even If it was unhelpful or didn't address your question whatsoever.
    Thank you for using FixYa!!
  • 3,037 Answers
Air conditioners are designed to remove heat from a room or cool it down and it will take some humidity out of the room but not all. Depending on the (SEER) Seasonal Energy Efficiency Ratio as to the amount a 12 and 13 SEER typically remove about 20 to 25% but that is not its purpose to remove humidity.
If you are only interested in removing humidity, then you should get a humidifier, but if you also want to cool the room then the air conditioner will work a little but not as much as what you may want which generally goes for all makes, though this one may be a little worse than similar makes. To help in dehumidifying you would want to lower your indoor air flow over the evaporator (lower the blower speed as low as possible by using the manufacturers minimum airflow recommendations). Since it is so high, I would also get the humidifier like I previously suggested above as that is meant to specifically remove humidity especially if it is so high. Let me know how this turns out.
Benjamin
Posted on Jul 27, 2009
  • Benjamin Patri
    Benjamin Patri Jul 30, 2009
    Yes it is just something that you will live with, this unit sounds like it is running correctly if it is cooling. They won't be made exactly the same as other brands and so a dehumidifier would be in your best interests to help keep the humidity down. Sorry for the bad news, though I would complain to Mitsubishi and see if they would pay for the dehumidifier or towards it since the unit isn't so great.
Blocked tv without remote. how to unblock
You DON'T! You need to buy either a replacement or get a universal remote from Best Buy.
Jan 19, 2014 | Air Con 18,000 BTU 13 SEER Mini Split...
Suction line size on midea minisplit heat pump is 1/2" suppose to be 3/8" what problems will that cause?
An undersize suction line decreases the capacity, and causes the compressor to work harder and more frequent starts. It may even experience low suction pressure and high superheat.
Dec 16, 2013 | Midea 18,000 Btu 17 SEER Inverter Mini...
Mitsubishi Heavy Industries Cassette Out Door Model: FDC506HES. What is the BTU size?
1 ton of ac is 12000 btu. you should probably call mitsubishi they have a tech support that will help you with this. the number is usually in the paperwork that came with the unit. you may find it on the tag where you got the model number
Oct 15, 2013 | Mitsubishi MSZ-FE12NA MUZFE12NA Mr Slim...
Mr. Slim aint cool!
Unit short of refrigerant or outside condenser very dirty. Clean outside thoroughly and make sure there is plenty of warmth coming from it when working.
Jul 07, 2012 | Mitsubishi MSZ-D30NA Mr. Slim Wall Heat...
How do i get the squirell cage oout of the mr. slim mitsubushi room unit to clean it?
don't think you want to do that. it's a pain to get out and more of a pain to get back in. HVAC supply houses sell coil cleaner that will break up the dirt on the cage and have it easily removed.
Jul 15, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr slim ductless ac choices
Try this Air Conditioner Sizing Worksheet from Consumer's Reports. It will help you.
I hope you find this information to be very helpful to you moving forward.
Please leave a rating. :-)
May 09, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
If i have a room 16x24 how big of a electric baseboard heater do
It is not the size of the room that is important it is the heat loss of said room. If it is a inside room, with no outside walls, it will take less btu's to heat and maintain comfort levels, where as if it is a room with floor to ceiling windows, you will obviously need more btu input. Hope this helps.
Mar 03, 2010 | Fahrenheat Electric Convector Baseboard...
Mr slim unit in bedroom 9kbtu - room 11x12'- is humid, awful
Lets clarify. DRY mode only dehumidifes that air and does not cool. Cool is used for cooling. Dry mode doesn't normally have temp control; it is automatically set by the unit. I think 9000btu is a big unit for the room; it is overkill. I would switch to a 5000btu unit. it cannot be fixed and the BR unit needs to be uninstalled and the new unit needs to be re-installed. The price of commisioning, de-commisioning and new unit is something in which you will have to pay.
I take the time to answer your questions, so please rate me.
Thankyou
Mat
Aug 26, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
