N
Natalie Burrow Posted on Aug 21, 2017
I plug my ipod into the stagepas 150m pa into the appropriate jacks and the graphic equiliser is working but no sound comes out. How do I open the pa to sray lubricant on the connectors inside?
5 Related Answers
Anonymous
  • 55 Answers
  • Posted on Jan 27, 2008
SOURCE: dock connector port
Try going to repair your iPod at apple.
I don't think they will accept it because it is a old version.
You can try.
Hope this helps!
Nicholas
uge44
Eugene Tetlow
  • 226 Answers
  • Posted on Nov 19, 2008
SOURCE: ipod plays with no volume
If the sound isn't working from the headphones then normally it's just a new headphone/hold switch cable that's needed, but if it's not working from the docking bay either then you have a problem with your logic board.
LVT7857
Larry Tezekjian
  • 117 Answers
  • Posted on Jan 28, 2009
SOURCE: I have a male ipod
If your Sony has female RCA Aux inputs, then you can use that going headphone out of MP3 player to the RCA inputs. You won't be able to view or controll any other player from the head unit except an iPod.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
ipodslinger
Steve Brown
  • 688 Answers
  • Posted on May 17, 2009
SOURCE: ihome won't play ipod, even
Welcome to the wonderful world of the iHome frying the Ipod.
Your iHome, has most likely fried the mainboard on your ipod.
to check plug a usb into the ipod and connect to the computer.
if it comes up disconnect the usb and try a headphones in the jack.
if it doesn;t play sound its fried and you will need a new mainboard.
if it does play through the headphone jack, your lucky and keep it off the dock.
I have fixed at least 30 ipods taken out by ihome docks and other docks.
they are terrible for the ipod. Even Apple sells the docks on their website
that shows how much they care about the product.
If this helps leave a vote on fixya
wizzard1970
  • 12 Answers
  • Posted on Apr 26, 2010
SOURCE: No Sound from External Speakers....only from Headset plug.
Hi, had same problem.... unscrew the remote and carefully remove the back end part of the stereo-connector (very careful !) it consists of a very small switch which moves sideways..... this switch is stuck into headphone-modus. Reassemble and it will work again
Note that speakers will work if you remove the switch
Testimonial: "Super info you've given...Thanks. Was going to replace it, but your suggestion is even better. Do you have to remove the switch to remove the casing?"
How do I connect a Yamaha MW12CX mixer to a Yamaha Stagepas 500?
  1. Connect the output of the Yamaha MW12CX mixer to the input of the Stagepas 500 using a standard 1/4" instrument cable or an XLR cable. Connect the output of the mixer to the "LINE IN" or "MIC/LINE IN" jacks of the Stagepas 500, depending on what type of output signal you're sending from the mixer.
  2. Set the levels on the mixer and the Stagepas 500. Turn down the master volume on the Stagepas 500 and set the individual channel levels to zero. On the Yamaha MW12CX mixer, set the faders for channels 1 and 2 to the unity gain position (usually around 0 dB).
  3. Set the input mode on the Stagepas 500 to "LINE" or "MIC/LINE" for channels 1 and 2. This will ensure that the Stagepas 500 is receiving the correct input signal.
  4. Adjust the levels on the mixer and the Stagepas 500. Slowly turn up the volume on the Stagepas 500 while monitoring the levels on the mixer. Make sure the levels are not too high and that there is no clipping or distortion.
  5. Once you have the levels set correctly, you should be able to hear the sound coming through the Stagepas 500. Adjust the EQ and other settings on the Yamaha MW12CX mixer as needed to get the sound you want.
Note: The Yamaha Stagepas 500 has two more channels available, channels 3 and 4, which can also be used for additional inputs from the Yamaha MW12CX mixer or other sources.
1helpful
Stagepas 300.Why does one of the mic volume controls, have to be at full level to hear anything through the speakers the others are OK ?
I would suspect the input jack on that channel is either bad or has a leg come loose from the circuit board.
Yamaha Stagepas 300
short.. main out mosfets are damaged.
Need to repair my stagepas 500 mixer
Hi
the right speaker input from the mixer sometimes in goes out! Usually when base are low. However it does it along in the middle of a song.
I have put w40 in the hole and it works.
when I fist got it I had to take it for repairs but it never went away completely.
what could it be?
I have a stagepas 300 it turns on but wont produce sound
I once had this problem. Turns on but no sound. I tested the fan next to the power supply and it ran rough like it was worn out. I found the fan on eBay A5010L12S and replaced the fan. The Stagepas 300 came back to life. This fan blows toward the power supply and the other fan sucks air to create a circulation of air inside the mixer.
NO sound comes out of the headphone jack or the bottom plug in
All you need is a new headphone jack as yours may be messed up, or it may need to be checked as the cord may have came loose and just needs to be reconnected. They are pretty cheap to replace so it will not cost alot to fix.
For Tascam DP02 can't record and listen
Assuming your PA is a Yamaha STAGEPAS (although I thought 500 watts per side was the biggest one you could get). Anyway, on your PA's panel you will have the karaoke machine(s) plugged into the CD ins (top of the panel), while closer to the bottom you'll see the 'monitor outs' L and R 1/4 inch jacks. These are where you'd run the L and R from the PA into your Tascam (or L alone for mono out). The monitor outs are line level and are good for independently powered speakers, recording equipment, mixers etc. Just avoid using any outputs labelled 'speakers'.
bd.
Top The Audio Players & Recorders Experts
vince
Paul Carew
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
