Question about Exercise & Fitness
Once you step on the moving treadmill the belt stops pro-form cs7e
  • 24 Answers
Try standing on it then starting it, some units have a saftey curcuit that cuts th motor if there is a spike in service Voltage level this how the machine detects if you have fallen and shuts off
Posted on Jul 27, 2009
Pro form 320x treadmill stops working when you get on it
How can I get my Proform 320X treadmill from stopping a ...
www.shopyourway.com > Manage My Life > Questions
How can I get my Proform 320X treadmill from stopping a few seconds after starting? ... -why-does-my-proform-treadmill-belt-only-move-a-few-seconds-stops
ProForm Treadmill 320x User's Guide ' ManualsOnline.com
fitness.manualsonline.com > ... > ProForm Treadmill
ProForm 320x Treadmill User Manual. Page 1. Page 2. Page 3. Page 4. Page 5. Page 6. Page 7. Page 8. Page 9. Page 10. Page 11. Page 12. Page 13.
Nov 03, 2015 | Exercise & Fitness
Slipped belt
there are two bolts on the rear of treadmill walking deck. these are adjustment bolts. start with the belt going 3mph. tighten the side where the belt is closest.only go 1/4 turn at a time.give it 15-20 seconds for belt to track or move over. continue until centered.
Apr 17, 2014 | Proform Pro-Form 520 ZN Treadmill
How to recalibate a pro-form 595LE treatmill.
follow this steps and fix it. God bless you
The Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Dec 09, 2013 | Proform 595LE Treadmill Walking Belt
When running on our treadmill the belt slips.
Hello, It sounds like you have aslipping front roller pully. Remove the motor hood and watch the front roller while you are on it. Once the belt is moving slowly, try to stop the wlak belt by planting your fett for a second, if the walk belt stops, but the drive belt and motor continue to run, the plastic pully is slipping and the whole front roller will need to be replaced.
Hope this answers your question.
Jan 16, 2011 | Nordic Track NordicTrack A2750 PRO...
My belt is skipping on my Pro-Form 750
At the end of of the running belts in the end caps will adjusting bolts you will need a allen wrench to adjust the tension. Start your treadmill and turn clockwise a 1/4 turn each time see i f you can stop the belt. You need to be aware that the drive belt can also cause this problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped or the roller has stopped and motor is rotating ( adjust Drive Belt)
Mar 01, 2010 | Exercise & Fitness
Pro Form treadmill display lights up but the touchpad doesnt respond and belt doesnt move
Check out The treadmill Doc. Fantastic site and great people to do business with. A lot of helpful trouble shooting information for free! I'm betting it is the motor control board. Site will lead you through step by step instructions to check and fix it yourself. I saved a ton of money and with a little know how and good information you can too.
Dec 16, 2009 | Proform Sport 1000 Folding Treadmill...
Pro-Form 360P, when I step on the belt, it stops moving.
when the belt is stopped you should be check the deck if this it´s worm or the walking belt, because a probable cause is lack of lubrication, In addition should send the engine to revision, because according to what your gross probably already there are some Diode Rectifier damaged, You must know that the cause that generates this problem stems from the walking belt and the table or deck
Jul 16, 2009 | Proform XP Weight Loss 620 Treadmill
Pro-Form XP 550 Troubleshooting
My Proform 550 doess not work the treadmill is not getting any power. Wht might the problem be.
Apr 27, 2009 | Exercise & Fitness
Exercise & Fitness Logo
266 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
