SOURCE: the motor of my V Fit Los Angeles 2 treadmill
I would start at treadmilldoctor.com. I have had very good luck with them so far. They have parts and expert troubleshooting. If anything they might be able to steer you in the right direction
Testimonial: "Thanks for this information, very much appreciated. Regards"
SOURCE: i have a pro form performance j4 treadmill. i
It is just plastic. You can wedge a piece into the slot
SOURCE: can you get power to a treadmill without the
Hello there. Yes you actually can use a magnet. (thats all the safety key is) It will need to be strong enough to make the switch inside the console activate. I use one from a telescoping magnet used for picking up small screws (available at the big box stores) when I dont have one on service calls.
Just to let you know a refrigerator magnet will not be strong enough!
Good Luck! Tim
SOURCE: Treadmill (Vision Fitness T8500) turns on, motor doesn't run...
open motor shroud and inspect all connection on the motor control board see if all LED 's are lit except that light up when incline motor is moving up or down. then check the two connector coming from the drive motor to the board sometime over time the two connector will have a cold soldier I would move them to see any excessive movements of the pins then hit start and see if there is any belt movement. Last but not least unplug unit and check the motor brushes if they are less than 3/8 in in length replace them. Call them @ 1-800-335-4348 they under their parent corp. Johnson fitness.
SOURCE: I lost my safety key
I just found out I had lost my key too. I have a Merit 710T. I called the company and they directed me to their website.
http://store.horizonfitness.com/c-33-safety-keys.aspx
On the page there is a link to a chart which will tell you what key is right for your model. They are cheap, only @ $13. Not sure about S&H though. I've also heard that if the key is a magnet you MIGHT be able to use another magnet to complete the circuit. I'm going to try this when I get home to tide me over till I get my next check and order a new key.
