SOURCE: problem with tv sender
Hi,i learned on another forum that if you connect an hdmi cable apparently it disables the functions of the scart sockets,especially where the remote control is concerned.This is something to do with virgin media's setup and not any equipment fault.If you want to go back to two room viewing try unplugging the hdmi lead.
SOURCE: Cable box pass through
ur trying to downgrade the signal when ur running composite cords u need to either run the composite out or an hdmi out to upconvert the signal the svideo cant handle the composite
SOURCE: Wii and PC signals no longer reach TV
try to check the drivers and if necessary reinstall it and look.try to chech the settings and also the connection cables also.thank you
SOURCE: can no longer pick up router signal
Does the wireless light still lit on the router? You can try changing the channel on the router (1 6 or 11) ans moving the antenna. If those things did not work upgrade the firmware of the router and reset to factory default. Do not forget to save the configuration file before you reset to factory default.
SOURCE: After an upgrade which included using a box from
No Converter should be needed. Sounds like your wires are not connected right. Check your Panasonic and Comcast Manuals for correct wiring diagrams.
