Question about Bose 321GS Series II System
Dvd won't eject and picture froze
Was playing the dvd the screen just froze up won't move and now i can't get to open to remove the disc
  • 458 Answers
Try un-plugging the unit from the mains electric supply, leave it for a couple of minutes & then plug it back into the electric supply. This should re-set itself & hopefully eject the disc. If the disc had a bad spot or the laser did not traverse smoothly this will cause the disc to freeeze & lock up.
Posted on Jul 27, 2009
Dvd, no eject disc
It sounds like your DVD is not getting any power to it. When you press the eject button does it show a power light for a second and then not move ? Also it is possible that some other DVD could have been in it and now it is blocking the door to open, look carefully at the door there should be a very small round hole on it you can use a paper clip straightened out to make a probe and insert it in the little hole and push you will have to push firmly and it should open the drawer. I hope this helps
May 02, 2017 | Televison & Video
Blu ray player won't play or eject disc
If you want to eject the CD you need to look on the front of the Blu-Ray drive for a small hole, about the size of a pencil-lead. If you open a paper clip and insert it, it should pop the drive open for you.
Mar 06, 2013 | Televison & Video
Clarion ohm107vd in car DVD won't eject disc
It not the disc, it won't take a disc ...... if I go to put one in it Makes noise but won't actually take the disc. Would this be the loading gear and can it be fixed or?
Jan 08, 2012 | Clarion Car Audio & Video
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
URGENT! DVD not ejecting or playing.
It seems you will need to open the damn thing, or search for a tech, verify your warranty, dont void it.
First you can try to move a little bit the dvd, unplug and plug, change disc, ieverything that can move a part inside the dvd must be pressed, surely is stucked between the play and the open stage.
Jul 17, 2010 | Pioneer DV-515 DVD Player
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
Sunia LTD-1720 17" Color LCD TV and DVD Player Combo with Remote
i have a sunia tv anddvd combo need a remote and programming instruction for it. the remote model is rc518n than you
Apr 26, 2008 | Televison & Video
Go Video VR 1940 DVD Recorder + VCR - DVD disk will not eject from slot on top of flat screen TV
My sugestion is to open the dvd player cover, then after you remove it the disc cover you screw out it to remove your disc.
Apr 24, 2008 | GoVideo Go Video DVD/VCR Combo
LAPTOP DVD DRIVE WONT PLAY DVDS ANYMORE
Drive is on its way. Typical behaviour. Try air dusting lens but unlikely to fix it. Very easy diy repair and cheap. EBay the new disc drive or refurbished. Then go to youtube. Nearly all laptop drives are the same to replace no matTerry brand. You could even get a faster drive.
Mar 05, 2017 | Televison & Video
DVD RW stucked - stall the whole system.
Hi, I found this site today cos I had a similar problem. To cut a long story short I found a slot on the bottom of the machine, below the disc tray, that has a white lever in it. After removing the power source I moved the lever to the side and the tray opened manually so I could remove the disc. It seems It was a duff DVDR as other discs now work fine. Good luck !
Oct 15, 2007 | Philips DVDR3440H DVD Recorder/HDD...
Bose 321GS Series II System Logo
123 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
