Cars & Trucks Logo
Glenys Redford Posted on Aug 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jeep 2000 has a clunk clunk noise when I turn full lock on left and right turns I have put new axils+front drive shaft in but still there and when I'm driving it seems to get louder please help
Clunking noise when turning on full lock and when driving it seems to get louder
Rick M
Level 3:
  • Jeep Master 4,148 Answers
  • Posted on Aug 21, 2017
Rick M
Jeep Master
Level 3:
Answers
4148
Questions
0
Helped
1254729
Points
13941
Bad control arm bushings, worn ball joints, worn inner/outer tie rod ends.
5 Related Answers
Anonymous
  • 59 Answers
  • Posted on Jun 19, 2009
SOURCE: I have a loud clunking noise that happens when I
The clunk you are hearing when the car is placed into drive is the "slack" in the drive train being taken out. It should pose no problem and without knowing the type of car you are driving is difficult to judge if it may be something more serious. If anything it could be the universal or CV (constant Velocity) joints making the sound from excess wear. The clanking when the wheel is turned could be CV joints getting old and needing replaced (Front wheel drive and 4WD only. Rear Wheel drive Universal Joint) or it could be excessively worn parts in the steering system. Definitely have this looked at.
Anonymous
  • 30 Answers
  • Posted on Jul 29, 2009
SOURCE: 99 Jeep grand cherokee steering column makes a clunking
power steering pump might need more oil (whining noise). generally power steer pumps take automatic transmission fluid. there should be a reservoir above the pump only fill this a little bit then start the car and turn left to right and recheck level. fluid should only be low if there is a leak at power steer pump/lines or steering rack,
Dennis Sharp
  • 154 Answers
  • Posted on Dec 06, 2009
SOURCE: Loud Clunking when jeep starts moving in drive.
may be the gears in the rear end or check your motor mounts, ive had the noise and it was motor mounts
Anonymous
  • 14 Answers
  • Posted on Dec 09, 2009
SOURCE: Car makes a clunking noise when I turn to the left
YES , THIS IS CERTAINLY YOUR LEFT OUTER CV JOINT, IT'S EASIER & CHEAPER TO REPLACE THE LEFT CV SHAFT
Anonymous
  • 85 Answers
  • Posted on Feb 24, 2010
SOURCE: LOUD CLUNKING NOISE IN REAR WHEEL AREA WHEN TURNING LEFT
sounds like either a sway bar end link or shock, more towards the end link tho
1helpful
Easy way to check nois in front diff on a 1999 BlazerZr2. Have front drive shaft off.
Turn a tight right hand circle and listen for noise then turn a tight left hand circle and listen for noise. This checks the CV joints in the axles. Ujoints are cheap you might as well replace them while the shaft is off.
Mazda axle shaft
not anymore than any other front wheel drive car. are you having a noise(clicking or clunking) coming from the front only when turning. if so then you have a bad cv joint on the axle. its cheaper to replace the entire halfshaft(axle) than just the bad joint, as you get a rebuilt halfshaft complete. if you hear the noise when turning left then the left halfshaft is bad if you hear it only when you turn right then the right side is bad. you don`t say what issue you are having.
Steering failure
sounds like the gear box or sterring rack went out have some one move the wheel look see what is moving and wha tis not
2answers
I have a 2005 Pontiac grand am and every time I go around a corner, doesn't matter if its a left or right turn, I hear what sounds like a grinding noise coming from the front of the vehicle near the...
this might help:
Here is the Technical Service Bulletin that maybe of help, worth looking into but can't guarantee that it would fix your problem Steering - Steering Column Clunking When Turning TECHNICAL Bulletin No.: 01-02-32-001P Date: November 25, 2009 Subject: Clunk Felt/Noise Heard From Steering Column, Steering Gear and/or Front Of Vehicle During Turning Maneuver and/or Steering Wheel Rotation (Replace Intermediate Shaft As Directed) Models: 2001-2004 Buick Regal 2005-2008 Buick Allure (Canada Only), LaCrosse 2000-2008 Chevrolet Impala 2000-2007 Chevrolet Monte Carlo 1998-2002 Oldsmobile Intrigue 2004-2007 Pontiac Grand Prix Supercede: This bulletin is being revised to add the 2008 Buick LaCrosse/Allure. Please discard Corporate Bulletin Number 01-02-32-001O (Section 02 - Steering). Condition Some customers may comment on a clunk type noise coming from the front of the vehicle while driving during a turning maneuver.
1. Locate a large area (parking lot) where the vehicle can be turned in a tight circle. 2. Turn the steering wheel to the right and/or left all the way to the steering lock, then off the steering lock a 1/4 turn. 3. Drive the vehicle approximately 5 km/h (3 mph) in a circle, preferably over rough pavement or seams on the road surface. 4. Drive the vehicle straight ahead at idle speed while applying and releasing the brake pedal. Listen/feel the steering wheel for the clunk/noise condition. 5. If a clunk is felt in the steering wheel, the MOST likely cause is the I-shaft - not the steering gear. Continue with the correction. Correction DO THIS - Replace the intermediate shaft DON'T DO THIS - DO NOT lube the intermediate shaft Replace the existing intermediate shaft
1helpful
2answers
My 1998 hyundai excel glx has a clicking sound front left wheel when turning
that would most likely be your drive axel when they go bad they click when you turn the steering wheel
1helpful
Clunking noise when turning boxer van
One of the driving shafts cv bearing worn out ,Drive in the park turn left not noise turn right you have noise ,notes right turn noise is left cv and left turn is right vc join .2nd the most of the times the long-standing shaft damage the cv bearing first..
What could cause clunking sound on front left os car when turning into a dip?
Check the ball joints,drive shaft first for uneven and excessive wears.
2helpful
Hi i have a grand cherokee 2003, lately when
It seems as though one of your front drive axle universals has failed and locked up. The other possibility would be a dry steering knuckle. Thank you, Dana
2000 jeep grand cherokee ltd
check lug nuts. then have brakes checked if lugs are OK.
Noise from front
Is it full time or part time 4 wheel drive? You should check the front driveshaft u-joints.
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
