Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Convergence lines above center left below center right side scree
Can not get convergence lines on the same side of the center line of the tv screen
i end up with shadow lines
telivison is a pt-47wx52
  • Panasonic Master
  • 3,459 Answers
You can get complete convergence kits from www.TvRepairKits.com
Posted on Jul 31, 2009
    Problem Solver:
  • 8 Answers
Your TV has a convergence problem. You can get the parts, instructions, and repair support from www.TvRepairKits.com
    Champion:
  • 230 Answers
Hi, thank you for visit fix ya.
Solution:
Replace STK 392-110 ( with stk 392-150 is better).
for parts, go to:
http://www.encompassparts.com/
Check any possibles resistors open or blown beside stk ICs.
Thank you
Posted on Jul 28, 2009
The left side of the picture is distorted with a double image. The right side is fine. As things such as the stock symbols on CNBC scroll across from right to left on the screen, they start out looking...
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the cursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It takes time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
You can pay somebody to do it, but may cost you like 100.00 or do it yourself, it is very easy just tedious and time consuming. If you have the auto convergence than your golden because this is the easiest way to "reset" the TV.
Hope this will help in solving the problem....
Jan 12, 2011 | Hitachi 51GWX20B 51" Rear Projection...
43fdx15b Hitachi 42in red vertical lines magic focus inop for red
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors.Shops usually charge from $200-$300
Sep 26, 2009 | Hitachi Televison & Video
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Convergence lines are SLANTED. Red line is above
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Apr 26, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Convergence lines are SLANTED. Red line is above horizontal center on left side on screen and below horizontal center on the right side of screen. Also left of Vertical center at the top of the screen and...
did you check the six 3.5 pico fuses that are next to the ICs? They will often be open ( blown) when the ICs fail. Also check the two 5 amp IC protectors on the G board as those protect the two ICs so its possible they have blown also a 5 amp pico can be substituted for the two IC protectors.
Apr 26, 2009 | Sony KP-46WT500 46" Rear Projection...
PICTURE HAS DISTORTED HORIZONTAL LINE IN CENTER OF SCREEN.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 03, 2009 | Toshiba 55H70 55" Rear Projection...
Ok, so I Replaced stk-392-110 (2) and......
Check the resistors in the red convergence circuit right next to the Ics you will need to lift one side of the resistor out of circuit to acurately check them but usually one or two resistors will be opened when the ICs go out
May 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Samsung 52" rear projection tv convergence problem?
THE PROBLEM IN YOUR TV. IT'S THE CONVERGENCE. YOU NEED REPLACE THE CONVERGENCE STK'S AND AFTER THAT YOU NEED DO ADJUSTMENTS.
Jan 14, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Convergence Problems
GREEN-YOU HAVE TWO STK392570 CONVERGENCE ICS' GETTING READY TO FAIL.SOME FOLKS HAVE REPLACED THEM ON THEIR OWN,OR YOU CAN GET A REPAIR TECH TO DO IT FOR AROUND 300.00$.JOE TV
Oct 29, 2007 | Mitsubishi WS-55819 55" Rear Projection...
JVC A56P575
In the customer menu page thru it until you come to a page that has an item called convergence. move the cursor down to hightlight this and press enter. The next screen will have an Auto on the top line and a Manual of the second line. Hightlight the auto and press enter. The TV will attempt an automatic convergence alignment. BE WARNED>>>It will either correct it or make it worst. If it gets worst then the TV's convergence circuit has aged and is starting to fail. If it corrected it it's the same aging but not as bad, YET. If there is no change or it got worst then you will need to have the TV serviced preferbly by an authorized JVC service center because they have access to the service literature and buttetins.
Oct 08, 2007 | JVC AV-56P575 56" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
188 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
