Question about GE 36 in. Profile JGP962 Gas Cooktop
We have a 5-burner GE cook top/ The igition for the center burner continually fires.
I have to unplug the electricity to stop the ignition from firing
  • 213 Answers
Re: We have a 5-burner GE cook top/ The igition for the...
The spark modual is bad in the cooktop. you can just leve it unpluged and light with a match until you can get it replaced
Posted on Nov 22, 2007
0 characters
3 Points
Gas cooktop starter continues firing
Turn your gas valve on, but leave your unit unplugged for a few days. You can light your burners in the meantime with a lighter so you can cook. Usually this problem is caused by moisture getting into one of your ignitor switches which are under your burner knobs. Most of the time the switch dries out and you can plug your unit back in after a few days. If it still keeps firing then you will have to replace one or more of your ignitor switches. Usually a very difficult job as most gas cooktops are now sealed burner units which means the top of your cooktop is bolted down to the burners with several screws or nuts that heat up with usage and become almost impossible to remove, without having to drill out the screws, or chiseling off the nuts. Be careful of boilovers or cleaning around the knobs with too much water to prevent this from happening again. Also get a surge protector at least 2000 joules or higher to prevent damage to you spark module. Good Luck, Appliance Specialists
Dec 16, 2009 | GE 30 in. JGP336 Gas Cooktop
My ignitor on my ge cooktop keeps clicking slowly in off mode
As it relates to 5 burner gas cooktop Model Number JGP 963SEJ1SS
First - Ignite the flame then reduce the flame to between low and medium.  If the igniter continues to click, you most likely have a contact switch issue related to the problem burner.
Unplug the cook top and turn off the gas.  After the gas is turned off, disconnect the gas line.
Remove the cook top.
Unscrew and Remove ALL of the burner bases by lifting them up.  The ceramic igniters may be difficult to remove but they will come loose if worked out slowly.
Pull of the wire connected to the igniter.
Remove to cook top top plate from the base, exposing the internal gas valves and wiring.
All of the burners are wired in parallel.   Lift off and unsnap the casing of the problem igniter switch.  The repair may require something as simple as, 1- cleaning the contact strips, or 2- slightly bending the non stationary contact strip to keep it from coming in contact with the stationary contact when in the off position, or 3- replacing the switch.
Unless you comfortable and understand how electric systems and switches work, this is a job for a qualified repair person.
Apr 02, 2009 | GE Cooktops
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Stove top ignition doesn't stop ticking
My Dacor cooktop had a similar problem of continuously clicking igniters. I unplugged it a couple months ago and used a piezoelectric igniter to get it started. Then I looked in the Dacor FAQ and it said to clean the ceramic igniter posts with alcohol not water. I had to scrape some gunk off a couple of the posts with a knife before cleaning with alcohol. Now it works.'
I think the igniters use electrical conductivity to detect when they need to spark, so even slight invisible contamination on the igniter insulator can confuse the sensing system. Also they all seem to fire as a group, so all of them need to be clean because if any one of them is dirty then they will all malfunction.
Mar 22, 2009 | Creda Colonial 42352 23 in. Electric...
Spark igniters on the burners fire continuously
When cleaning, if the control switches get damp, they will react as you describe.
Unplug the appliance, use a hair dryer and attempt to dry the switches.
Leave it unplugged overnight and try them again tomorrow.
They will eventually dry and be OK.
Feb 24, 2009 | KitchenAid 31 in. KGCC505 Gas Cooktop
Ignition sparking on its own with GE mongram gas stove top.
the sparking is one of the switches under the knobs shorted you may be able to open the top and take a switch off 1 at a time and you can figure out what one is shorted.or you can just change all of them.
to stop this you may be able to just unplug the cooktop from under the top.if you unplug the cooktop you should be able to light the burners with a match.
Nov 14, 2008 | Cooktops
Electronic ignition
Most likely you got water (or some other liquid) into the control knobs. Unplug, go to bed and try it again in the morning. If you continue to futz with it, you run the chance of burning out the electronics in the control knob, like I did. :(
Oct 22, 2007 | Miele 35 in. KM326G Gas Cooktop
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
GE 36 in. Profile JGP962 Gas Cooktop Logo
366 people viewed this question
Top GE Cooktops Experts
Barrett Palumbo
Barrett Palumbo
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a GE Cooktop Expert? Answer questions, earn points and help others
