Question about Cell Phones
My phone was working fine, battery drained, charged, now no pwr!
My phone was working fine, battery drained randomly, now is fully charged and won't turn on. Tried removing the battery. Nothing. Tried USB charger, no change. I don't know what to do!!
Pwr str shows on display
Its difficult to diagnose this particular issue without knowing the year, make, model and engine size of the vehicle in question?
May 02, 2017 | Cars & Trucks
My phone drains out battery quickly
If the battery is more than one year old, it has simply lost its ability to hold a charge. Replace the battery with a new one, charge it fully before using the phone again, and it should be fine.
May 25, 2014 | Cell Phones
My blueant s4 won't charge
It must be a battery problem as the battery indicator level says full when you remove it from the charger and the phone doesnt work.
Mar 19, 2013 | Blueant Ant S4 Handsfree Voice Controlled...
While charging on AC works absolutely fine. But while discharging i.e. Running on battery, shuts down unexpectedly. The same also happens when the the AC adaptor is plugged out at random. Lastly, the...
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 10, 2011 | Computers & Internet
I dropped my phone in the pool, got a new battery for it and it worked fine untill the battery ran out and now it will not charge or turn on (lg xenon)
Since it's a new battery it might be the battery. If a battery will fail it will do so with the first 30 days of use. It sounds like you have never charged it before. You should bring it back to the store for a replacement to test it if possible with another phone. But since the phone suffered water damage the real issue is most probably the phone. If a phone gets wet sometimes it will work fine for a while after it dries or it won't work at all. But even if it does work you could start having random issues with it everything from random shutdowns/reboots, can't charge, can't stay on to issues like preventing you from receiving txt msgs or using the camera or media player. You might have to start shopping around.
Jul 07, 2011 | Cell Phones
Battery is fully charged. phone power randomly shuts off.
Hi, When a cell phone is fully charged and the cell phone randomly shuts off,IT means that the battery of the cell phone is ok ,but the cell phone memory is faulty and it need to be checked out.
I this kind of case, i would advice you take it to an expert on phone repairs tohelp you look into it. That will do..
Hope it helped /..
Thanks for using fixya,
Feb 03, 2011 | Motorola Mobility RAZR V3m Cellular Phone
Phone is charged but is continuosly losing power. How can batteries run down when it is charged?
Unless the phone is showing any malfunction we cannot confirm unless a drain test is taken in the standby condition of the phone.This must be quite negligible current about few mAmps . If there drains is more check for leak in the battery source to the IC feed, a possible zener shorting or a capacitor leaking.
However if the phone is using up power on talk time , it can be due to drain in a functioning circuit which will be hard to find , but check for unusual heating in any components.
If however the phone works fine then it can be the fault of the battery itself as it could have developed reverse polarity.
Let the battery drain off fully and recharge, if possible a jump charging with an external voltage might sometimes cure this issue.
If not change the battery with the correct current rating.
Sep 26, 2010 | GE 27992GE5 Cordless Phone
Screen shows battery with a red line through it
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in.
Feb 16, 2009 | RIM BlackBerry 7130c Cell Phone
Hi k750i,phone works perfect but won,t hold a charge for long,even with new batteries. thank you
Before you change the battery:
  1. Charge the battery fully
  2. Discharge the battery fully
  3. Repeat steps 1 and 2
If the battery does not reset itself and start lasting longer then you do need to replace it.
If that does not work the phone will require repair of the leads from the charger to the battery or the battery to the phone
Jun 26, 2008 | Ericsson Cell Phones
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
