Question about Sony Cyber-Shot DSC-S40 Digital Camera
Camera Stays running
When I turn my camera on it sounds like it's still running. When I switch the tab over to the right it shuts off. When I take a picture it starts running and doesn't turn off. What could this be caused by?
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
I click the on button on polaroid i834 digital camera, then stops
Sounds like the battery is too low. Replace/recharge batteries.
Oct 03, 2009 | Polaroid i834 Digital Camera
Olympus sp510uz no sound on video
From SP510 camera switched off:
1. Turn dial on top plate to movie mode (selections from the menu screen apply to the mode the camera is set in);
2. Switch on SP510 power;
3. Press "MENU" button on back plate;
4. Select "Camera Menu" from screen if not already on it, using navigation buttons on back plate
5. Scroll down yellow "Camera menu" tabs to microphone picture (below "Digital Zoom"), which may be showing "off". Select OK and toggle yellow tab from "off" to "on", then press OK button.
6. Microphone tab should now show "on".
7. Return to main menu (press MENU button).
8. Return to image screen (press MENU button).
9. Test to see if video now records sound.
10. If is still doesn't record sound, try "reset" from video menu screen (this will reset the movie mode to factory settings, including microphone on).
Dec 21, 2008 | Olympus SP-510 UZ Digital Camera
Canon Powershot SI screen goes black after taking a photo
That sounds like a sticky lens shutter. They usually have to be replaced, as they usually will need parts. When the camera is working look inside the lens and take a picture(with flash turned off). You should see a black shutter door clicking shut in the lens. When the camera acts up, look inside the lens again. If the door is staying shut full time, that is your problem.
Nov 17, 2008 | Canon PowerShot S1 IS Digital Camera
CAMERA TURNS OFF WHEN IN PICTURE OR VIDEO MODE
Does the camera turn off or does the screen go black? if the screen goes black but the power lamp stays green then the screen is just turned off (power save mode), If it’s just the screen to turn on the LCD. There are 3 buttons just to the right of the screen, press the center button.
May 20, 2008 | Sony Cyber-Shot DSC-P52 Digital Camera
Fujifilm F650 Zoom Error
My camera stays open, will not shut, and when I turn it on the screen says "zoom error" and then turns off again
May 20, 2008 | Fuji FinePix F650 Digital Camera
I turn camera on and it shuts off immediately
I had the exact same problem, it would shut off after trying to turn it on. The door to the memory card has very small tabs on it that push in some kind of sensor inside the camera when you shut the lid. It starts up when I push in the sensor.
Mar 24, 2008 | Fuji FinePix S3000 Digital Camera
Camera stays on
this sounds like a systemic problem. (responding to 3 different inquiries with similar complaints)
the light stays on when writing to mem to warn/prevent you from losing images which happens from premature power down actions.
in this case you have signs that the mother boards are bad. call canon for advice,but i am sure they will instruct you to ship them for service. aside from damaging your camera, it does not sound like a user interaction issue.
good luck
mark
Dec 02, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Camera will not operate
Use the audio-visual cable that came with your camera and connect your camera to your TV.  Now turn-on your camera and switch to "view mode", e.g., to see a already taken picture on your LCD.  You will not see anything on your LCD but may see an image on your TV, even if the image is "F18".
I used the above trick to clear an F18 error on an A75.  Right now I am trying to get the camera to focus properly, but somehow the above cleared the F18 error.
If the above does not work, try connecting your camera to your computer's USB port using the other cable that came with the camera.  Your camera will want to be on, and in the "view mode".  I have read that this trick can reset an F18 error.
Good luck.  At least it costs zero to try these two tips.
Oct 11, 2007 | Canon PowerShot A75 Digital Camera
My caamera won't stay turn on.
hi Tony your camera shows a problem in its lens or related mechanism so its solution is not on net.run to the sony shop....
Jun 15, 2006 | Sony Cyber-Shot DSC-P73 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
20 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
