Question about Ovens
Frigidaire pleb27s9dca. Something blew the fuse in the our basement fuse box. Only the fuse that the oven is connected to. When I reset the fuse, everything on the front panel appears to work, but the oven does not heat up at all.
  • meltemi Jul 28, 2009
    Thank you for your help...I'm going to call in a pro. I was hoping for a simple "just replace this sacrificial part" solution.
    the solution was very thorough but beyond my capabilities.
  • 3,037 Answers
Alright, start with a visual inspection. For this part of the testing, kill power to the oven. That means to turn off the circuit breaker. Inspect the element with a flashlight, look for obvious burned spots or separations.
Next if everything looks good, then test the oven element. This will include basic electrical measurements since the element can look fine from the outside (and usually does) but the inner core, the part that electricity flows through and gets really hot, can be electrically open.
So, we’ll start with a simple resistance measurement of the bake heating element. To do this, you have kill power to the oven and then remove the visible and obvious element retaining screws. Then remove at least one wire from the element; you can, of course, remove the entire element from the oven. You’ll be making the measurements with a multimeter available at any electronics store like radio Shack on the element’s terminals.
Measure the resistance with your meter; anything less than 50 ohms is good. If you’re seeing a high resistance reading, like something in the thousands of ohms (denoted with the “K” on most meters) or infinite, then just found the problem and need a new element.
If the element tests good, then it’s time for live tests. That means voltage on the circuit.. If you don’t know how to safely make live voltage measurements, then stop reading right now and call a professional. You’ll also need the wiring or schematic diagram of the oven– these are usually hidden inside the control panel compartment, some disassembly required. Make sure you’ve killed power to the oven before going any further.
Before we get into the actual live test, it would helpful for you to know how the bake element works so you’ll have some insight into how the live test is done. A bake element operates at 240vac, 120vac is supplied to each side of the heating element. One side is tied more or less directly to L1 or L2 (both of which are tied to 120vac)– see your model-specific wiring diagram, I’m just ’splaining the strategery here.
The other side of the heating element is connected to the electronic range control either directly or through some intermediary controls.
Now, here’s where the real strategery comes in. The basic idea is that when the bake element is turned on, BOTH sides of that element should get 120vac (remember, the element is supposed to have 240vac to heat up properly). So we’re going to split the problem in half by seeing which side of the bake element power circuit isn’t coughing up its 120vac.
Power Leads to an Electric Bake ElementOk, here’s how we do the live test:
* kill power to the oven (which you already did earlier, right? ;) );
* disconnect one wire from the bake element and then secure it so it doesn’t touch anything else
* clip the common side of your meter to any known ground point, like an unpainted metal surface in the oven;
* re-apply power to the oven;
* measure voltage at both of the element power wire leads;
* the one that isn’t giving you 120vac is the circuit you need to troubleshoot; you can ignore the other side.
See, you just cut the problem in half! Now kill power to the oven again and focus on the wiring diagram and locate your problem circuit. Then identify the next component in line between the end of the heating element wire with the missing voltage and wherever it ends up, be it the circuit board or one of the power lugs on the terminal block in the back of the oven. The rest is trivial. Continue applying this essential data until you find the missing voltage in that circuit. Let me know how this turns out.
Benjamin
Posted on Jul 27, 2009
Troubleshooting power issues for whirlpool accubake double oven
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
Mar 02, 2015 | Whirlpool Ovens
Oven does not heat
Apr 18, 2014 | Frigidaire Ovens
No power after self cleaning
5.
6.Even a bad relay door switch will hinder your oven from operating.
Dec 14, 2013 | LG LWD3081ST Electric Double Oven
Sparks from the thermostat control! - frigidaire oven
you may have blown the control board. or blown the ac main control fuse for you home wiring. this is in your fuse box cookers have there own fuse separate from other appliances.
Jun 13, 2017 | Ovens
Element blew in oven; now stove doesn't work....
Sounds like the loose oven element caused a short circuit, which may have fried a wire inside the range. Or, it may have tripped the circuit breaker (or blown the fuse) for the range circuit. Check your electrical panel. If the circuit is open, don't reset it until you've removed the remnants of the oven element.
Sep 14, 2009 | Frigidaire Ovens
Frigidaire Caprice Oven won't work
i have a double caprice oven and the top oven wont go - something to do with timers
can u help
May 12, 2009 | Frigidaire FEB27S5A Electric Single Oven
GJP85200 Whirlpool Oven display went dead
First you need to check if a supply is available to the machine. The safest way to do this is with a non-contact voltage detector. You can get one for around £10. (Also called volt sniffers by some) If you have an electrical supply to the machine I would call for service, use yell.com to contact your most local cooker engineer. If there is no supply you need to check back at your fuseboard to find out why.Have you reset all the trips?. Is there a spur with a fuse in it between the cooker and the fuse box?
Apr 04, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
How do i install an oven thermostat?
You crossed wires or missed one and blew something out.
Feb 16, 2009 | GE JKP15 Electric Single Oven
Bake or broil does not work
if an element itself had shorted it would not stop the other from working and you could inspect each element and see blistering as evidence.the pop you heard has to be in common with both elements but not the cook top[burners]so thats going to be the wiring in the back of range, or switching,[thermostat,clock timer or oven selector switch,depends on which model you have]you will have to pull range and remove back pannels.you will find an obivous burn't connection.too repair all new connections must be clean and tight,or will burn again.
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
97 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
