Question about Kenmore 22422 Top Load Washer
Washer will wash
When finished washing it will blink LF and wont go into rinse.
  • 6,784 Answers
HI. this will occur if the pressure switch near the inlet valve becomes unstable. it will not detect water flow. this will trigger the LF code. the pressure switch will need to be replaced asap. this will fix this issue.
Posted on Jul 27, 2009
Rinses light flashing fast and wont drain drum and finish wash
Try checking the filter for a blockage or pump being jammed with a button , disconnect drain hose at sink hold a few feet off ground over a bucket should pump/ flow quite freely if not then check filter and pump. good luck
Oct 13, 2014 | Miele Novotronic Premier 500 Front Load...
Why is the machine Not rinsing and spinning?
something is blocking it from draining so it wont spin and it wont rinse because it wont spin
Jun 10, 2014 | Brandt WFH1176 Front Load Washer
Washer wont go through the cycles... it stops working before the final rinse cycle
MAH5500B Maytag Neptune washer stops and I have to put back into star and not just wash one side wet clothes and Susie sige water drains can only hear a buzz and it takes many items and each shaved marked "nf" and "Lf"
May 29, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washing machine displays an LF error code. Started last week during whitest whites cycle in rinse. I cancelled and just did rinse to finish my load. All other cycles worked and yesterday all started...
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The spin cycle wont start as the rinse cycle finishes i here two clicks 1 to 2secconds appart and then nothing
Not sure which model you have, but if it spins after the wash cycle, and not after the rinse cycle, it is more than likely the timer.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
My washing machine wont rinse and spin, after washing it will beep as if it was finished doing the washing.
A hotpoint WMA30 does not beep on any program as there is no 'beeper' on the pcb. The 'end' led illuminates when it finishes on any program. The most common cause of no rinse or spin is a blocked filter or drain hose. If there is water in the drum when it has finished then this is the probable cause. However if it's empty when finished and has not spun then either the belt has come off or the motor brushes are worn to a point that there is no contact with the motor armature.
Apr 17, 2009 | Hotpoint WMA30 Front Load Washer
Washer wont run error code lf
my washer wont fill up and is blinking Sd
Dec 15, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Fisher paykel washer
Sounds like you could need a new out of balance switch or bracket, also try to make the clothes evenly spread in washing machine on rinse if they clump up on one side of the bowl they will cause out of balance :)
Sep 07, 2008 | Fisher and Paykel GWL11 Top Load Washer
Ariston 6kg washing machine
Do you have the "easy iron" feature on? If so, the clothes will stay in water until you manually rinse it.
Oct 07, 2007 | Ariston Technologies AWD 121
Kenmore 22422 Top Load Washer Logo
53 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
