SOURCE: cub cadet 1641 lawn tractor won't start
Beings you can get to the solenoid I would check it first. There is a small post (not battery or starter), touch a jumper wire from battery to this post. Then with a test light check the wire to that post w/key in start position (remember you must be in regular start condition for this test). If no light, you can only go to each switch one at a time and bypass then try to start again. Not sure how many there are.
SOURCE: cub cadet LT1046 will not start. Battery shows 13
This is most likely a ground problem. Remove the ground wire where it goes to the battery terminal and make sure it is clean. Then remove where it bolts to the frame and make sure that end makes contact with bare metal.
SOURCE: switch shuts off cub cadet but will not start it if u jump solioid will start
The fuse good? 20 or 30 auto fuse.
