Question about GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS
Ice machine ice comes out but water does not, what does this mean?
  • GE Master
  • 4,654 Answers
It is most likely the dual water control valve on back and near floor. The side that controls the water to the dispenser is possibly defective. Here is a link to the water control valve below. Click on it.
WR57X10032 Water Control Valve Here is a photo. Ice machine - 9fa9bac.jpg If you should need help and if you have and OHM meter we can test the coils and voltage sent to that side of the valve. Feel free to let me know if you have any questions, Thanks, Sea Breeze
Posted on Jul 28, 2009
Scotsman ice machine water runs continually never shuts off. It will make ice but really racks up water bill. It is as if the float never senses the reservoir is full. What is my problem?
OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
Jan 12, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
22mssa Ice machine does not work
Because you get water going to the water dispenser does not mean that the water control valve going to the ice maker is good. What is the model number of your refrigerator? If the water control valve going to the ice maker is defective you will need to change the set located on the back of your refrigerator near floor where the water from your home attaches to the refrigerator. Thanks Sea Breeze
Apr 05, 2013 | Whirlpool Refrigerators
Ice machine working but very slowly
I am not sure about the commercial ice, but I would check to make sure the water tube that goes into the maker does not have an air bubble in it. That can cause the water not to come into the freezer to make the ice cubes.
Aug 25, 2012 | Hoshizaki Freezer Commercial Ice Machines...
My ice maker doesn't make enough ice cubes
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in.
Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
Jun 16, 2012 | Kenmore Side by Side Refrigerator
Water in door but none to ice maker-why
couple of things to check make sure there is no obstruction where the fill tube comes into the icemaker... if ice builds up in plastic tube it will not allow to come into ice maker... if there is ice there most likely the water valve is not closing all the way... these are normally dual water valves meaning one solenoid goes to ice dispenser /water dispenser and the other works the ice maker good luck
Dec 31, 2010 | KitchenAid KSCS25FKSS Side by Side...
My model AM-50bae ice machine has water in the storage bin,what can I do?
check the bottom of the bin for a drain spout. The drain line may be clogged allowing the water to build-up in the bottom.
If the water is coming down from the ice machine itself, you will need to open up the machine and look inside. Check to ensure the cube guides have not come out of place, that the sump is not overflowing with water, and that there are no loose, leaking, disconnected, or busted hoses.
Jun 06, 2010 | Hoshizaki Freezer Commercial Ice Machines...
I have model 630 mwf water cooled keeps beeping twice i reset clean machine water well clean float will cycle a few times and then beep again what should i do next
Hi, I have worked on these machines many times, air and water cooled. Do you have a code chart on a panel to tell you what the 2 beeps are on the control board? Do you have the original troubleshooting manual? This would be of a lot of help. This KM900 is a good size ice machine. I would pick up a gallon of nickle safe ice machine cleaner at a refrigeration parts house, read the instructions and run the machine through the cleaning cycle again. Hand clean everything you can get to again, this is the biggest problem I find on water cooled units. The nickel safe is an excellent cleaner made for this problem. Do you have a water softener for the inlet water on this machine? If not I would recommend having one installed. This will cut down on a lot of problems you will have in the future. Try this and get back to me and let me know. In the mean time I will research this ice machine to see what I can come up with.
Shastalaker7
Feb 16, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Why is the orange light on , what does the orange light mean?
If the bin is full there is a light that stays on. If it is time for a cleaning, there is a light that stays on until reset.
Jan 15, 2010 | Scotsman Ice Machine, Cuber, 1930 lb....
3 yr. old Hoshizaki km630 mah, Had a hard freeze(24 degrees) at the shop and checked the ice maker that sits outside main bldg. Main water supply line inside that joins the copper pipe to the plastic...
There should be a reset button on your control board inside the electrical compartment.
Turn the system on to ice mode and depress the reset button. This should clear out any and all faults stored in the board and the machine should at least attempt to come back to life.
Look on the outside of the electrical compartment cover. There should be an explanation of what your error code means. I can't remember it off the top of my head. But the list there will tell you what 1 beep every 305 seconds means and the procedures to take from there.
Jan 13, 2010 | Hoshizaki Freezer Commercial Ice Machines...
My ice freezes together!
Do you mean the ice cubes are too large to be individual cubes and come out as a lump? The water is filled by a timed fill so if the fill solenoid stays open a little and drips water into the cube tray it will have more water than normal. I guess I'm not sure if you mean the ice cubes are stuck together in the tray or are they sticking together in the holding bin area?
Jan 30, 2007 | Kenmore 74172 / 74174 / 74179 Top Freezer...
GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS Logo
55 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
