Question about CMS ABSplus (096122038182) 100 GB Hard Drive
My 2002 Vanden Plas need a ABS module and pump. What should this cost and is it OK to use used parts? Thank you!
  • 4 Answers
First problem is that it's part Ford (kidding) and uses Ford electronics, not as bad as Lucas, but still... Make sure it's the abs and not just a sensor or the sensor's connector. Ford uses an internal sensor located in the differential on many vehicles.
Posted on Jul 28, 2009
2004 Jaguar, Vaden Plaus,car just quit running going down the road. Had to have it towed home Won't start,turns over, just won't start,says Restricted Performance.
Sounds like it is some type of 'limp home' mode.
It could be anything. It might be as simple as a bad Fuel Pump Relay. When you turn the Key to the ON position (not Start) can you hear a little buzz for about 1 second? That would be your fuel pump running. You need to see if the engine is getting gas and spark.
Jan 05, 2016 | Cars & Trucks
How do i reset the engine control module in my 1995 jaguar vanden plas 4.0 will this reset ALL setings because i think this car needs it had 3 owners and cant seem to get memory and othe little things.
I'm not sure what you mean by "reset" but have a look for an OBDII / EOBD AUTO SCANNER (there's usually one or two on ebay.) Is that the sort of job you want to do?
May 26, 2014 | 1995 Jaguar Vanden Plas
Abs light and traction control light stays on after repairs
I wonder if someone forgot to reconnect the connector from the sensor?
May 13, 2014 | 1995 Jaguar Vanden Plas
Heavy gas smell on 2000 jaguar vanden plas
check for a bad fuel filter or a leaking rubber line after the fuel pump . To dump that much fuel so quickly ,the fuel pump is pumping to a broken /split hose or steel line.
Dec 12, 2013 | 2001 Jaguar Vanden Plas
Jaguar Vanden Plas 1996 where is the fuel pump located?
this is a picture of fuel pump location hope it can help you and good luck
Nov 18, 2012 | 1996 Jaguar Vanden Plas
How do I replace the fuel pump on a 1989 vanden plas
it is underneath at the rear driver side wheel. remove the wheel. disconnect the battery. disconnect the wires to the pump...usually blue. Connections to the pump from the tank and out from the pump are more complicated. Change the fuel filter at the same time. You will need to clamp the fuel line and you will spill some gas no matter what. It is awkward to do it on your back and well worth an hour of a mechanic's time...but it is do-able
Oct 27, 2009 | 1989 Jaguar Vanden Plas
CMS ABSplus (096122038182) 100 GB Hard Drive Logo
32 people viewed this question
Top CMS Computers & Internet Experts
Arora Singh
Arora Singh
Donna Sander
pankaj rautela
pankaj rautela
Are you a CMS Computer and Internet Expert? Answer questions, earn points and help others
