Indesit WDE12 Dryer not heating
About a week ago it displayed F13 and now the dryer doesn't heat. With instruction I am competannt enough to fix it.
  • 1 more comment
  • planet5 Jul 28, 2009
    This maybe the reason for F13 but I don't see how this would affect the heat from the tumble dryer part.
    I measured the element it definatly needs replacing should I change anything else while I'm doing it. Also the F13 I have checked the pipes and they are clean, I haven't checked the electrics yet.
  • planet5 Aug 03, 2009
    The information was great. Replaced the heating element and cleaned the pipes and it works fine. Thank you very much.
  • 3,037 Answers
The code F13 means to Check the water supply, inlet valve and hot and cold hose connections, check for clogs or inoperable valves. The instructions for checking the values if you find no clog and have good water pressure can be found below.
Before testing the water inlet valve, unplug the washer or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valves are blocked or the solenoids do not activate, the symptoms may include no water, low water pressure, the wrong water temperature or water entering the tub even when the machine is off.
Water inlet valve
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water
pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.
There are two wires connected to each solenoid (aka coil) on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Inlet Valve
Use a continuity tester or multitester/multimeter to test for continuity (these testers can be bought at an electronics store for fairly cheap). Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. Test the second one in the same way as the first.
If the solenoid is working properly, but water leaks through the valve even when the washer is off, then the valve itself is the problem. Debris may be preventing the valve from closing. If the valve cannot be cleaned, it will have to be replaced. The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Let me know how this turns out.
Benjamin
Posted on Jul 27, 2009
  • Benjamin Patri
    Benjamin Patri Jul 28, 2009
    Well if it tries to run but just won't heat, then test heater element with an ohm meter. You will read continuity across a good element ( 8-12 ohms is an average element ). If you don't read that, then replace it. Does the machine run or try to run?
    If the machine won't even run, then the first thing would be to replace the door switch (if it doesn't click) or the timer dial
    You can get all parts from www.repairclinic.com where you can return them within 30 days if replacing the certain part doesn't fix the problem
  • Benjamin Patri
    Just replace the element for now, you can get a new one from www.repairclinic.com
What to do with F13 error indicator on my indesit washing machine please.
Dryer temperature sensing fault (washer dryers only)
Issue: Washer dryer is not drying clothes.
Advice: We recommend you call our customer service centre to book an engineer on: 0344 822 4224
Mar 31, 2017 | Indesit Washing Machines
Tumble Dryer intermittent squeal, then stopped heating, now black soot underneath
Dryers are susceptible to lint fires in their exhaust vents. You should be checking the exhaust vent at least once a year and clearing any blockages. If the exhaust vent becomes blocked, the dryer will heat up significantly and the lint could catch fire if there is enough heat build-up. If you don't clear the exhaust this will almost certainly happen.
Fire needs a source of heat (red hot heating elements), fuel (lint) and oxygen (the exhaust fan blows air at the blockage).
You should be able to replace the burned out heating element if you are comfortable doing the wiring. You can pay a repairman if you like but wiring is only so much common sense. Photograph the wiring before you start for a post repair check. Replace the element and any burned wires. Make sure the connections are tight and that there are no loose wires. Only the ground wire should be bare.
A Dryer uses 220V AC (in North America) like a stove and some water heaters. This is enough voltage to kill even hardy souls who laugh at 110V (usually enough to kill but not guaranteed to).
When you check the vent, check that it has some sort of safety rating. Not all flexible vent is fire-resistant. This scared me when I saw it on YouTube or somewhere.
Why did your smoke detector not go off when the element melted?Good thing to know if your utility charges less for power in off-peak hours. My mother often runs hers at night when the rate is very low.
My dryer runs from sunrise to sunset but we use an electric one in the winter months.
Sep 20, 2012 | Indesit IS70C Electric Dryer
Indesit IS70C tumble dryer not heating
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 10, 2012 | Indesit IS70C Electric Dryer
Dryer runs but no heat. My husband is pretty smart with appliance fixes. Do you think that this thermal fuse solution would be easier enough for him to fix or should we get a repairman?
The thermal fuse is not going to be the problem...when the thermal fuse has gone out the dryer will not start so since it runs the thermal fuse is good. The number one thing that is wrong with a gas dryer when it doesn't heat is going to be a broken igniter,this tip i wrote explains what to check when a gas dryer doesn't heat http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 12, 2011 | GE DBXR463GD Gas Dryer
Indesit condensor tumble dryer does not heat up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 08, 2011 | Indesit IS70C Electric Dryer
My indesit dryer is IDV65, the drum is spinning but the dryer is not heating up and the clothes are still wet.
heatman101
Jan 05, 2011 | Indesit Dryers
Reset on indesit dryers not heating
heatman101
Nov 01, 2010 | Indesit IS70C Electric Dryer
Hi,my indesit IS70C tumble drier works but does not heat up.\possible causes please.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Indesit IS70C Electric Dryer
My indesit is70c tumble dryer is just blowing cold air,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Indesit Dryers
Hotpoint Washer Dryer WD865 - Dryer Problems
thermister blown or thermal fuse which is a black plug in the top of the dryer box or yellow sleeved wire, if it was noisy maybe the fan has come loose from it's motor. you will need to remove the dryer box on top of the drum to see if the fan is binding. you can push it back to where its not binding and tighten the nut-ANTICLOCKWISE, LEFT HAND THREAD.
usually the machine runs through a check before starting a cycle and will see an f13 and not start even a wash., so you will need to replace the blown parts.
Oct 25, 2008 | Hotpoint Ultima WF865 Front Load Washer
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
