Question about Sony FD Trinitron WEGA KV-34XBR800 34" TV
Picture bowing in center from top down about 1 inch in middle, ok at edges, also looks as if degause is inoperative with colors on left and right (purity) --------------------------------___________________------------------------------ like that, I checked continuity on degause coils, ok. checked voltages to degause coils, ok. Also I can hear the degause circuit at startup, however set looks as if degause circuit is not working. Can the bow be taken out from the service menu? How to enter service menu? Whats wrong with purity? Sony kv-34xbr800
  • 4,234 Answers
This is a convergence problem. Look for poor connections at the convergence ICs. Try resoldering the pins on the ICs. If that does not resolve the problem, replace the ICs.
Dan
Posted on Jul 28, 2009
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
Sony 46 inch proj tv picture is bowed in the middle and color is
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Oct 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Bowed picture and color misalignment
Replace both STKS ICs Ck low ohm resistors 2.7ohms most of the time there will be 2 of them bad.
Jun 11, 2009 | Samsung HCN5527W 55" Rear Projection...
Bows on sides
Try degausing the set with the system software. if this doesnt fix it you will have to degause the set with a professional tool.
Jan 27, 2009 | Mitsubishi VS-55601 55" Rear Projection...
Projection T.V. Picture
Replace Both of your STK ICs convergence ICs STK392-110 use 150s Better ICs Call Mats 1-800-628-1118 Also RK42 RK46 RK48 RK50 RK54 RK58 RK60 will have to get back to you on resistor values
Jul 21, 2008 | Hitachi 60SX12B/13K 60" Rear Projection...
Picture is bowed down from top left corner to top right corner and bowed up from bottom left corner to botton right corner. Colors are seperated a little in corners and middle top and middle bottom.
Convergence ICs are faulty what is your model number? I can post which ICs you need and where you can get replacements that come with free instalation instructions so you can do the repair yourself
May 07, 2008 | Televison & Video
Convergence issue with blue
You need to replace the convergence Ics located up front behind the speaker grille numbers STK392-110 you can get replacements at the following link and they provide free tech support and instalation instructions with pictures. heres the link.
http://servicemanuals.vstore.ca/
May 06, 2008 | JVC AV-56WP74 56" Rear Projection...
Covergence and Bowed Picture Problem
can you adjust any color of convergence in user menu blue, or red up or down left or right. if you can make any up or down left or right adjustments on any color then the likelihood it wont be a convergence ic. it would be a output resistor. so see if you can get any movement. with it being bowed i was suspect an convergence ic.
Jan 08, 2008 | RCA P60920BL 60" Rear Projection...
Sudden discoloration, ghosting, bowed horizontal lines in top and bottom of picture
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 10, 2007 | Samsung PCL6215R 62" Rear Projection...
The convergence ICs probably have a cracked solder joint on the foil side of the circuit board. Re-flowing the the solder would help. I will always replace the convergence ICs when doing this job. The labor remains the same and you will have to pay a few extra bucks for the parts. To fix this yourself, you will need to be able to identify the two convergence ICs, have a basic knowledge of electronics and be able to use a soldering iron. You will also have to do an alignment through the service menu.
Apr 01, 2007 | Samsung HC-P4752W 47" Rear Projection...
Sony FD Trinitron WEGA KV-34XBR800 34" TV Logo
165 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
