Question about Hampton Bay 24750 Huntington III Ceiling Fan
Hampton bay 52" fan RPM very low even at high speed
I have Hampton Bay 52 In. Waterton II fan and the only problem I have is even at high speeds it moves very slow (low RPM). What can be the reason for that. In another room I have Hampton Bay Garrison and its also 52" but its speed is very good. I never have to go above medium speed on that fan. So what can be the difference between these fans. The home depot website has no technical specification and when you go to there store their sales people do not know anything (i think that's why they stopped using that line anymore "you can do it and we can help" as they are not helpful at all). I fanybody has the same issue and have any solution please share.
Thanks
Soulvisitor
  • 1113 Answers
SOURCE: Hampton bay Fan 54 in
Sounds to me like the wall switch is faulty, replace with new or to prove that Im right, switch them and see if problem moves to other fan.
Posted on Dec 30, 2007
salt56
  • 373 Answers
I think one of the brushes in the motor may be at fault: not connected properly. Would require taking motor apart and checking
SOURCE: Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Posted on Apr 08, 2008
SOURCE: Hampton Bay Ceiling Fan - Clarington 503837 52"
It slides in above right above the ball, in the mounting bracket where the canopy is. You may have to kind of encourage it to go in there, and you will need to push wiring off to the sides and out of the way to help it have clearance to get in there.
Posted on Apr 15, 2008
SOURCE: High speed only 60rpm
I too just installed a 68" Altura and noticed a huge difference in fan speed. I spoke to a rep for the manufactorer and found out that the high, medium, and low rpms are 70, 45, and 25. The typical 52" fan has rpm speeds of 190, 130, and 75. The kicker is airflow. The 68" moves 7,808, 4,417, and 2,953 cfms on high, medium, and low; the 52" fans move 5,503, 4,087, and 2,509 cfms.
Posted on Jul 07, 2008
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
My Hampton Bay ceiling fan runs only on high speed and the remote has stopped working even after changing the batteries. Does Hampton Bay have a life time warranty?
Yes, look up www.hamptonbay.com and get their contact number from them. It sounds like your transmitter (Remote) has failed. If it were the receiver the fan would most likely not work at all.
Jun 09, 2010 | Hampton Bay 52 In. White Redington...
Zing ear switch from a hampton bay ceiling
Did you try Home Depot, Lowes, or any lighting supply store. It's a pretty common item, so they should all stock it
Dec 12, 2009 | Hampton Bay 52 In.Carriage House II in...
Altura 68" fans will not operate on high speed.
I jtoo, ust bought The Altura (68" fan from home depot)
Home depot makes hampton bay through various chinese manufacturers.................
The fan ran slow on high speed, and barely ran on medium or low.
home depot gave me a number for their tech department that knew right away.....that the capacitor(s) are defective in many of the Altura fans.
They are sending the capacitors in 3 days to me no charge.
They are located under the fan ( remember the white square plastic plug you had to connect and the 2 wires for the optional light kit?.....)That plug is for the capacitors that everyone is having a problem with.
My guess is they are under rated for a fan that big and are sending better ones to those with problems.
Hope this helps.
The number is:
1-800-330-3267
Aug 18, 2009 | Hampton Bay 24002 Ceiling Fan
Fan went from low to high in the middle of the night, won't
I suspect it isn't correctable with a battery change; the speed control element (an unknown semiconductor) has shorted and no longer can control fan speed.
I'm not sure where this is located but is likely an assembly in the hub of the fan itself or with the control in the wall. These are often not repairable items and must be replaced.
I think Hampton Bay is a Home Depot house brand and the might be able to help you.
Jul 27, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
No middle speed.
Replacing the pull switch (reostat) should have solved your problem. Try going to the internet at www.google.com and in the Google search box enter "Hampton Bay Fans homepage". If any of these suggestions have been helpfull, please rate my solution. Thanks D. Lange
Jul 31, 2008 | Hampton Bay Sidewinder 04890 Ceiling Fan
Jun 10, 2008 | Hampton Bay 24002 Ceiling Fan
Dec 29, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Hampton Bay 24750 Huntington III Ceiling Fan Logo
400 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
