SOURCE: galaxy s7 edge
Check with your sim card first whether it's working or not. If it is working, Try a factory reset.
If that doesn't work either,dial the following code and see whether you gets your 15 digit IMEI ( Don't post it here. Just see whether it is coming)
CODE : *#06#
If you see only a bunch of "0"s or just a "0" or an empty space, you'll need to restore your IMEI
If it is not the case, it should be a hardware fault.
SOURCE: How do you unfreeze your galaxy s7 edge when it's stuck on the start up screen
Soft Reset Frozen Unresponsive Screen Samsung Galaxy S7 S7 edge
Testimonial: "Thank you for the information, it work."
SOURCE: how do I track my Samsung galaxy s7 edge using imei number and/or Samsung account
You can look up for imei number on your Samsung account with your mobile number and the SIM number which is the number you get when you buy a new SIM card.
SOURCE: Need unlock code for Samsung Galaxy S7 edge
Network unlock means you are trying to use it with any other network? It happens when you insert sim card from other network & the phone is locked by the provider. It can be easily unlock by getting the At&t Samsung Galaxy S7 G930A unlock code from any reliable source like 24x7unlockcodes.com which provide At&t Samsung Galaxy S7 edge network unlocking
Testimonial: "Thank you"
SOURCE: At&t samsung galaxy S7 edge asking for sim network unlock pin for other sim?
Sim Network unlock Pin means you are trying to use it with any other network? It happens when you insert sim card from other network & the phone is locked by the provider. It can be easily unlock by getting the At&t Samsung Galaxy S7 edge sim network unlock pin from any reliable source like 24x7unlockcodes.com which provide At&t Samsung Galaxy S7 edge network unlocking
Testimonial: "Very Very helpful"
