Question about Philips 32PT6441/37 32" TV
Green light blinks, TV DOES NOT COME ON!
Was working fine 1 day. TV was off at least a month, when I turned it on (by remote) it buzzed, & green light just kept blinking
  • 1 more comment
  • DRPJR Dec 06, 2007
    Very similar problem. I can turn on TV, hear sound, no picture, 5 seconds later.... it cuts off and LED green light blinks. Happened all of the sudden.
  • steeleman Jan 27, 2008
    I have a 32 in. philips HD flat screen model no. 32pt9100d/37 it's 2 years 0ld and i had it repaired once already for the same problem. When you turn it on the green indicator light comes for about 10 sec. then blinks 5 rapid blinks pauses for a few sec. then blinks once more and then repeats that pattern over and over.
  • harley1950 Feb 17, 2008
    off and LED green light blinks. Happened all of the sudden. I saw the possible solution offered. Is this something I can do myself? I don't know anyone in this area that works on TV's.
    Genius:
  • 1,694 Answers
Install horiz driver kit # 483531057673 and replace weak cap in
horiz driver circuit = 47mf/25v.Fix applies to all L04.01U chassis..........................T.
Posted on Nov 25, 2007
  • Vista Electronics Feb 18, 2008
    Note: my solution applies to L04.01U chassis only.........T.
Panasonic 60" LCD Projection TV Turns off every 1-2 hours
What is the model# of your TV?
Do you see any blinking (LED) lights on the front of the TV?
How many blinks?
Which LED light is blinking, Power, timer or lamp?
Nour Sabre
www.aaatvservice.com
Nov 15, 2011 | Panasonic Televison & Video
Turn on tv...green lamp blinks several times.lights up but no picture...press any remote button timer in green blinks...tv turns off and goes to standby
The tv "LAMP"LED light indication flashes or stay lit?The tv projection lamp been in this tv like 1/2 or 2 years?Tv been on and used like 4 or 5 hours a day?Yes,than the tv projection lamp life are over.Require a new tv projection lamp.
Nov 17, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
Continuosly blinking green light and tv won't turn on.
Either bad capacitors -vented - on power supply board or bad E2P eprom board on DM board.Probably the capacitors-4-1000Ufd and 2-3300ufd.You should get expert help from reputable tv shop.Not really do it yourself fix either way.
Dec 15, 2008 | Sony KDS-60A2000 60" HDTV
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
65H81 remote and green screen
Yes you can get the service manual at the following link for 10.99 and they will contact you to see if you would like the manual emailed to you. Here is the link.
http://servicemanuals.vstore.ca/
Feb 02, 2008 | Toshiba 65H81 65" Rear Projection...
Green light just blinks
Four bad 1000mf/25v caps in DM module = Common repair
for qualified Mits tech..................................T.
Nov 11, 2007 | Mitsubishi WS-48513 48" Rear Projection...
TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Jan 11, 2006 | Toshiba 43H70 43" Rear Projection...
Philips 32PT6441/37 32" TV Logo
199 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
