IOS version 10.2.1
SOURCE: My computer keyboard works fine,
press the on/off button to wake it up, see if that resolves the problem
SOURCE: Bluetooth mouse disconnected after sleep
Turn off the option for allowing mouse to be put to sleep from mouse properties in device manager.
SOURCE: intellistation e pro acts as if booting, but doesn't
Its nothing but the port of your display cable in computer tower and the display card. If its inbuilt (on board) display card then the slot where the extention is linked. If you can then just open the tower and change the slot of the display card. 100% gurantee it would work.
SOURCE: PC to Wireless mouse and keyboard connectivity issue
Hi!
Try checking your power management feature, there should be a tab there that enable/disables wireless capability to during power save mode...
Hope it helps!
Testimonial: "Thanks for the advice. Power save was OK. There is a setting called "Allow Hybrid Sleep" This was set to "on". I changed it to off and all seems OK."
SOURCE: monitor will not wake up with keyboard or mouse
turn off the computer's power management, there is an issue with the video card/OS and your power management. Set the power management scheme for the monitor to always on, or disable power management in the BIOS of the computer.
