Question about HP LaserJet 5100tn Printer
Prints really light on left side of paper
I have an HP Laserjet 5100tn, that has previously been printing fine, here recently though when the paper comes out, the left side of it is really light, I have tried cleaning everything, and even tried changing toner cartridges.
Re: Prints really light on left side of paper
I had the same problem. I took the laser assembly apart (located at the top of the printer under the cover). There are mirrors inside the assembly and they tend to get dusty. My mirrors were much more dusty one side than the other. I cleaned the mirror and the print was the same across the sheet.
Posted on Feb 22, 2008
You might need to replace the fuser. You can purchase the mainteance and fuser kit from HP or other like ompanies.
Posted on Dec 15, 2007
0 characters
3 Points
Why does the 2550n printer not printing fully in the left column
Is the print quality poor on left side for all colors? You may have one bad cartridge. Create a paint document with Yellow, Magenta and Cyan squares on the left side and see if one color prints better than the others. You can also gently shake the cartridges to redistribute toner.
Sep 08, 2014 | HP Color LaserJet 2550n printer + HP Color...
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
I have HP laserjet 1018 printer and it makes noisy sound when it prints. But it prints fine though. What causes making this noise?
The noise is probably due to the print heads aligning and clicking. To try to make this noise a little quieter, clean and align the print heads.
Mar 23, 2011 | HP LaserJet 1018 Printer
Printer prints but crumples paper
I guess you have a roblem in your fuer assembly, replace it
Apr 07, 2010 | HP LaserJet 1300 Printer
My 5100tn is making clicking sound but not grabbing the paper... What should I do?
Check your print rollers
Here is a guide that can help you with photos and everything.
Jul 13, 2009 | HP LaserJet 5100tn Printer
HP LaserJet 5100tn Prints from Tray 1 when not aked
We are having the same issue.
I've tried everything and it continues to go back to tray 1.
Aug 22, 2008 | HP LaserJet 5100tn Printer
Printing problem
the problem exclusive between the drum or the fusser unit
Apr 25, 2008 | HP LaserJet 2550L Printer
Why is it printong crooked?
The problem can be with the software program. May be the formating of that particular text has been accidentally changed to italic. Or print the same on a plain A4 paper or slightly bigger paper than the check and see if you get the same problem.
Apr 22, 2008 | HP LaserJet 1320 Printer
HP LaserJet 5100tn Printer Logo
123 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
