Question about Roper RAS8445KQ Top Load Washer
No clips found! To remove top or front
My Roper RAX4232KQ's lid switch has fallen apart and is now inside. I need to get to the switch area AND inside to retrieve part. Tried suggestions here. There are NO clips in crack between top and front of washer ON FRONT area...would they be on the side area? Washer is full of clothes and water so don't want to try to move it to much as I have a bead back.
Thanks!
    President:
  • 1,776 Answers
Check out this diagram. Sure hope this helped and best wishes.
Posted on Jul 27, 2009
Roper washer
That could be your lid switch. You should hear an audible click when you shut the lid. If the washer act like it is trying but won't spin that could be the drive coupler. I have a page which includes a service manual HERE
Sep 24, 2012 | Roper RAX4232KQ Top Load Washer
My RAS8244LQO Rober washer won't spin . Can you
Usually a drive coupling or lid switch assembly, if this is a Roper washer. If you put the timer on spin and turn it on, it runs but wont spin then it is a coupling 99% of the time. If it wont start in spin then check your lid switch. This washer has a very cool design to get into the mechanism. The top console flips up, usually you have to take out two screws on each of the front corners and then pull the console forward and up until it flips upside down. Disconnect the lid switch wiring harness and take a large flat screw driver and stick it into the left and right hand slots that have the brass retainer clips . You stick the screwdriver straight down and then pry the clips out by pushing back on the screwdriver. Remove both clips, grab the outer washer cabinet and tip it towards you, at a 45 degree angle you can slide the front of the cabinet out from under the base and remove the whole cabinet. Now you will need to remove the water pump, two clips, leave the hoses on, the motor has two clips that sometimes has two screws holding the clips on. Unclip the motor wiring and remove the motor. You will see the drive coupling, three parts, one rubber cushion with 6 holes and two round discs with three fingers. The two discs are attached to the motor shaft and the transmission shaft. Usually you will see broken fingers, worn holes or cracked plastic when you have a bad coupling. You need to remove the plastic parts from the shafts, and install the new coupling by tapping them onto the shaft. I usually use a long 3/8 inch extension and a light hammer to tap the coupling on untill the coupling is flush with the shaft. Install the black cushion onto the transmission disc, line up the motor disc with the cushion holes, install the bottom motor clip first, and then the top motor clip. This ususally requires some strong thumbs to clip the top motor clip on. Reinstall the pump, the cabinet. Make sure the cabinet is on the side rails in back. Reinstall the cabinet clips, plug your lid switch wiring back in and reinstall the console. Good Luck.
Appliance Specialists
Dec 10, 2009 | Roper RAX4232KQ Top Load Washer
When checking out the lid switch on my roper washer as jsrock suggested in another post, i heard a screw drop from the inside of that area which caused the lid switch to become unmounted completely. also,...
Top lid pull up. Look in seam between top and front cover. On each side you will see where top clips to front cover. Put a screwdriver in there and lightly pry up till clip releases. Front cover will now pull up and be removed, so you could get what fell in.
Jul 26, 2009 | Roper RAS8445KQ Top Load Washer
How to replace dryer belt
Remove the filter from the top>
Remove the 2 phillips screws from the top (filter housing)
Use a putty knife to pop the top by compressing the clips
on either side of the top between the front and top.
NOTE: Once the top is up remove the screws inside
to get the front off and LIFT the front up
before pulling towards you so the bottom clips
won't break.Get the lid switch disconnected and set the front aside.
Oil the rollers and idler, vacuum out the lint.
The new belt goes rib side down on the tub. The idler mounts like the one pictured
on bottom right of these dryer belt routing pics:
Dec 16, 2008 | Roper REX4634KQ Electric Dryer
Roper top load washing machine
you may have a bad lid switch,or the lid is not making contact withthe switch . not recognizing the door being down the machine , for safeety reasons, will not advance any furhter
Nov 02, 2008 | Roper RAX4232KQ Top Load Washer
Roper RAX4232KQ - Top part of agitator won't turn
you need to install new agitator dogs . very in expensive. remove cap on top of agitator reach in and remove opaque cover. you should see a 1/2 " bolt remove that and pull up on agitator. pull apart two halves. disassemble. install four dogs. reassemble in reverse order
Feb 06, 2008 | Roper RAX4232KQ Top Load Washer
ROPER RAX4232KQ1 Does not spin
You most likely have a broken coupler between the motor and transmission. A new coupler cost around $10 and is fairly simple to replace.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
Post back and let me know what you find out.
Dec 02, 2007 | Roper RAX4232KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
201 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
