You have not provided the year of your motorcycle so here is the directions for a 2006 Harley-Davidson Touring Bike. If you need advice as to how to change a belt on a different model year post again with the model year and ask again. If you need directions on how to remove the rear/replace any or all of the rear wheel or the swing arm or the primary case or the starter or the front or rear drive sprockets or etc etc post another request and if I see it I will respond to it.
2006 TOURING DRIVE BELT REMOVAL AND INSTALLATION
Remove the rear wheel and the rear swingarm and then the primary chain case assembly and then the old belt from the transmission sprocket and then install the new belt on the transmission sprocket and re-install the primary case assembly, the rear swingarm assembly and the rear wheel.
