Question about Ovens
Whirlpool oven RB760PXYB failed when turned off during self-clean cycle, won't come back on. I suspect an internal fuse or fusible link. How can I access this item for test/replacement?
techman
  • 3130 Answers
SOURCE: Amana AOCS3040 Convection Oven
If I were you I would contact Amana and speak to their service dept. and tell them your problem as maybe theres a service bulliten out or a common repair and if that they would recommend someone who can fix this model.. I tryed to look up this model and I couldnt find it. If that dosent help Go to http://repairclinic.com and ask the repair guru there for assistance.. Good luck
Posted on Apr 25, 2006
SOURCE: Whirlpool RBS305PDQ11. After self-clean, oven won't heat up.
This seems to be a common problem with these ovens. The oven got too hot and the tco (Thermo cut off)tripped. This will have to be replaced. It is located behind the control board.
Posted on Aug 25, 2007
SOURCE: WHIRLPOOL OVEN
nice, it'd help me a lot thank you
Posted on Jan 19, 2008
  • 6 Answers
SOURCE: oven door locked
First check to see if you activated the "child lock-out". See your manual to deactivate.
You could also try unplugging the unit, or trip the circuit breaker in your home which supplies power to the oven. Wait 5 minutes and turn power back on. This will reset the controls.
Posted on Jan 26, 2008
aborcass
  • 2651 Answers
SOURCE: OVEN will not heat
you need to remove the oven from the cabinet, the fuse is located on back wall about 6 inches down directly between broil element leads
Posted on Feb 24, 2008
Clean mode electric current went off was off 10mentis when it came back on oven didnt
I have a whirlpool double oven too and replaced the control board last year the problem started with a F06 code and would reset when I power cycled for a while until it completely quit. Changing the control board fixed that problem. I just used my self cleaning cycle recently and the oven went completely blank on the control panel. Power cycle didn't do any thing. I checked 2 of the thermal cutoff fuses that are shown on most of the parts listing but the problem was with one that is not shown. The link below will get you to the part I replaced it's the power feed to the control board. Turns out that the worst thing you can do to your oven is use the self clean feature. Oven Thermal Fuse
May 29, 2014 | Whirlpool GBD307PDS Electric Double Oven
Kenmore wall oven self clean 2005 neither element works. Shortly after we did a self clean cycle.
Many Kenmores were made by Whirlpool and these are notorious for tripping the thermal fuse. They are not usually not resetable and must be replaced. If there is a button to reset it then it should stay down. It is probably bad. Without a multimeter you could connect the wires together and isolate them from shorting against any metal by using electrical tape and temporarily powering up the unit to see if the elements start to heat. if they do then replace the thermal fuse and reconnect the wires properly. Just be careful.
May 22, 2014 | Hotpoint UY46 Style Line Stainless Steel...
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    I have a Whirlpool Gold self-cleaning oven w/convection. Following a self-cleaning cycle the oven will not heat up. Is there a certain amount of down time that has to go by before it will function again...
    The self-clean cycle has blown a fuse in the rear of the oven. That thermal fuse must be replaced. Go to www.appliancepartspros.com and enter your model number. Find the thermal fuse on the diagram and then you can orfer the fuse from them.
    Aug 27, 2011 | Whirlpool Ovens
    Whirlpool Oven Died During Cleaning Cycle No Display Now Locked
    Had same problem with my KitchenAid. 10 years old. Ran self cleaning cycle, oven died!!!! Called repair. Appears to be thermal fuse. Part on order. Microcomputer had some brown spots on it. Tey wanted us to replace it too. But will wait to see if fuse is problem. Repair - $150 vs. $570. If it's the higher price, we'll buy a new oven before putting that kind of money into it. Will NEVER run a clean cycle again even if I have to buy a new oven.
    Jul 16, 2009 | Whirlpool RBS275PD Electric Single Oven
    Self cleaning oven won't start self clean mode
    NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
    Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
    Oven won't heat
    Unplug the power cord for thirty minutes, this should reset the oven.
    If this still does not work do the following:
    Press clean and then cancel. This will reset the appliance.
    If the error does not clear , then during the self cleaning cycle, the high temperature has probably damaged the temperature sensor probe, and it must be replaced.
    Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
    After usung the self cleaning function the oven no longer works
    Check for correct voltage at plug, in the mean time the oven will be disconnected from any power, see if it resets with no power for 10 minutes
    Nov 13, 2008 | Whirlpool RBD305PD Electric Double Oven
    Whirlpool rbd275pdb double wall oven died during self clean
    The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
    Mar 22, 2008 | Whirlpool GBD307PDS Electric Double Oven
    Cleaned oven now won't heat
    Probably what happened is during cleaning cycle the oven overheated the tco (thermo cut off). This is a thermo-fuse that is located behind the control board. It will need to be replaced.
    Aug 25, 2007 | Whirlpool RBS245PDS Electric Single Oven
    Ovens Logo
    112 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
