unfortunately, no. You would be better off Ebaying the actiontec and getting a dedicated router- the reason is that the only uplink on the actiontec is the dsl port- not ethernet. Theoretically you could mod the firmware to make the wireless an access point only- but it would still have the achilles heel of needing an uplink.
After my second call to Actiontec ended with the help desh hanging up on me, Actiontec did respond to an emailed plea for help and prompty provided a complex script which they labeled confidential to address this problem. The bottom line seems to be Verizon either installed hardware that is incompatable with an Exchange server or they did not configure the insallation correctly. In so many words, Actiontec feels it is a Verizon problem. I wish me luck in getting to the right place to deal with that, even though I am a Verizon stockholder.
if you mean username and password to setup the connection with security etc you will need to go to your routers page and login with a username and password. A few of these can be found here. ActionTec isnt a very popular make unfortunatly. http://artofhacking.com/etc/passwd-actiontec.htm
If the modem was pre-programmed for another service, such as Verizon, you will have to plug the modem into a wall and hold in the reset button on the back of the modem until it resets. Then load the AT&T software IF they provided you with such - the walkthrough is actually pretty good. If AT&T did not provide you the Actiontec or the software, you will have to go to Actiontec's website and download the Actiontec Installation Buddy and also follow the directions for downloading the non-proprietary version of the firmware (WARNING: do not update the player's firmware if ATT &T provided you with the Actiontec; the non-proprietary firmware will make the modem useless toward whichever service provided you with the Actiontec). Take note of the numbers taped on a sticker underneath your Actiontec - MAC Address, etc. You may need this information to complete the installation. Also, download the Actiontec manual - it will take you through the process, but it is not going to be easy to follow - know in advance that it is going to take time.
As you go through the Actiontec Installation Buddy process, it will prompt you to do a modem test - make sure the Actiontec is connected to the phone line and to your computer (via an Ethernet cable). It will do a modem test. If the modem test fails the first time, turn the Actiontec OFF, wait 10 seconds, and turn it on again. Try the modem test again - should work.
If AT&T did NOT provide you with the Actiontec, your task is going to be a bit tricky. If AT&T DID provide you with the Actiontec, it might be better to call their technical support for a walkthrough.
I think the screen you may be looking at is the Application layer forwarding screen, the drop down box being populated by DHCP clients, that's why it isn't seeing the DVR. The DMZ Hosting screen doesn't have a drop down box, it only requires an IP address to be entered.
