Question about Sony Playstation 3 (PS3) Console
After i installed update 2.60 when ever i turn on my system the main menu freezes up and i can't select anything or the menu won't even come up at all, when i can move around all the tabs say loading and when i go to select a tab from the settings tab it freezes up again.
  • 72 Answers
Download the lastest update from the playstation3 website to a Flash drive or USB stick, and install the update that way. It should then be back to its orignal state.
Posted on Jul 28, 2009
Picmeta PIE program freezes up when selecting files
Do your friends run 64-bit Windows? If not, then uninstall this from your PC and go to their web site. Try to find a version specifically for 64-bit Operating Systems.
If you cannot get it to work at all, then uninstall it completely, so it does not interfere with other applications.
-a.
Jun 23, 2012 | Computers & Internet
HP Pavillion hp5020us won't install drivers after reinstall of XP operating system
Your driver CD might got corrupted so, please try it out manually, You can perform following steps to install the drivers,
1. Insert the CD
2. Cancel the Auto Run or Do NOT install it from the driver menu.
3. Right Click on MY COMPUTER icon
4. Click PROPERTIES
5. Select the tab HARDWARE and click on DEVICE MANAGER
6. Right click on the device with Yellow question mark icon.
7. Click on UPDATE DRIVER
8. On the Next Prompt box Select Install Automatically and click NEXT button to continue.
9. Repeat same for other devices.
10. Still having problem follow this URL http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=1842155 and click ob CHECK NOW button.
Jan 03, 2012 | HP Computers & Internet
My ps3 freezes upon start up, or shortly after. sometimes it freezes when trying to get into safe mode. sometimes i just get a black screen and my controllers won't connect. everything worked fine on...
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck
Aug 15, 2011 | Sony PlayStation® 3 (60 GB) Console
My Phillips GoGear Vibe won't go to the main menu. It freezes up on the ViBE sequence. I tried soft resetting and turning it back on but it didn't work!
Reset the player using the pinhole. If it freezes again then please update the firmware on the player to resolve the issue
To update the firmware perform the below task:
  • Download the newest version of the Philips Device Manager:
  • www.usasupport.philips.com - change your country/language as needed
  • Enter in your exact model #
  • Click on the link for your exact model #
  • Click on the Software & Drivers section
  • Click on "Firmware Upgrade Software"
  • Install the new Device Manager
  • Open and run the "Update" tab
If you need any further help, please email us back so that we can continue to work on a solution.
May 14, 2011 | Philips GOGEAR SA6045 MP3 Player
Unit freezes in play, red ring of death, will not eject disk
The PS3 has a special Recovery Menu, which you can access in the following way:
1. Turn off Playstation 3.
• Restart System: Restarts the PLAYSTATION 3 System.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• System Update: Update the PLAYSTATION 3 System
From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
Thank you !!
May 25, 2010 | Sony Playstation 3 (PS3) Console
Ps3 slim turns black when i select modern warfare 2
your PS3 is freezing simply because your console is affected by heat, so you have to cool it down.
If the freezing continues even after cooling down, you can follow the steps below:
To stop the PS3 from Freezing, you could begin by putting off your console and wait for 20 minutes. After that, put it back on.
Check if there's any loose cables. If there is, put them back in.
If the freezing continues after taking the above step, you can follow the link below as a guide on how to fix the problem.
http://www.squidoo.com/PS3-Repair-Guide
You can also try the steps below. Its from PlayStation Forum:
well as cookies.
If after trying the above options and it still does not solve the problem, then maybe the lens is weak and that's why it cannot read any disc.
I wish you good luck.
Mar 22, 2010 | Sony Playstation 3 (PS3) Console
RECOVERING GATEWAY LAPTOP WITH RESTORE DISC WE BOUGHT BUT IT FREEZES WHEN IT GETS TO THE WINDOWS XP HOME EDITION SECTION
I grabbed this from another site. It worked fantastic, give it a try and it might fix your problem, I know it helped me tones after spending nearly 2 days playing with a similar sounding problem as yours.
URL: http://forums.techguy.org/hardware/582490-freezing-during-full-system-restore.html
Gateway Laptop Freezes during System Restore
Had the same problem, turns out it's a well known issue to Gateway and Microsoft it's due to "SpeedStep" and it must be disabled. Here's the chat log with Gateway tech support:
do these steps to disable SpeedStep in the BIOS Setup Utility and then run System Restore again on your computer.
1. Turn on the computer and begin pressing the F2 key in one-second intervals. If you perform this step correctly, you see the BIOS Setup Utility menu. If Windows loads normally, repeat this step.
2. In the BIOS Setup Utility, press the RIGHT ARROW key to select the Advanced menu.
3. On the Advanced menu, change the Intel SpeedStep setting from Enabled to Disabled.
4. Press the RIGHT ARROW key to select the Exit menu.
5. On the Exit menu, select Save Changes and Exit
6. Restart the computer and run System Restore.
7. After completing the restore, download and install the Critical Update for Windows XP (KB885626) package from the Microsoft Web site.
8. Once the KB885626 package is installed, re-enable Intel SpeedStep in the BIOS Setup Utility.
Myself...I am not going to turn SpeedStep back on it caused me enough time and hassle that I don't want to take a chance that it will screw something else up.
Hope that helps anybody that finds this issue too. I got here by Googling but didn't find a fix anywhere on the net until I chatted w/ Gateway. And if the Laptop was not under warranty, they wouldn't have talked to me. Sad that it's a well know issues and one cannot even search their site for "a known issue"
Good Luck!
Mike
Jan 23, 2010 | Gateway 7330GZ Notebook
Nextar ma852-801 mp3 freezing...reset?
Hi.
Welcome To Fixya Community.
Solution 1:
  • Try to Turn it ON/OFF(Reset).
If that isn't Working try This:
Solution 2:
  • You are going to upgrade the Firmware of your Mp3 Player in order to perform that follow these Steps:
  • Installation of the Upgrade Tool:
  1. Download the Upgrade Tool application (the download link is in the bottom of this Solution) to your computer.Double click the application.Follow the instructions shown on the screen to complete the installation.Firmware Upgrade:Note: All the existing files in the player will be erased while upgrading,please make a copy of your files before doing this.Turn on MA852-801 player. Press and hold the MENU button todisplay the main menu. Select “Settings” → “System” →“Upgrade” and press the MENU button to confirm. Select “Yes”and then connect the device to a computer via USB interface once you see the following window:
2. Select ”Program files” 􀃆 ”Firmware Update” from the Start
menu or double click the “Firmware Update” icon on the
desktop. You will see the following window shown on the
screen:
6fc021c.jpg***************************************************************************************
3. Click Open button, and specify the upgrading firmware with
the extension “ .rfw ” (Please download the firmware from
Nextar website named MA852-801 – updated firmware.rfw).
Click Update button to start upgrading.
Note: This process may take about 2 minutes depending on the
computer system you use. Please don’t disconnect while upgrading,
it may cause serious damage to the player.
4. Once it shows "Firmware update successful"wording in
“Update Info” window, then click Exit button to finish
upgrading.
*************************************************************************************(5) 5. Safely remove the player from the PC.
6. Turn on the player. Please wait about 20 seconds for the
player to automatically initialize settings.
Downloads:
Upgrade Tool.
Firmware File.
Additional Help:
Nextar Ma852-801 Mp3 Player Manual Guide.
please don't hesitate asking me if you need any Further Info.
Thank You For Using Fixya.
Good Luck.
Nov 04, 2009 | Audio Players & Recorders
When I turn on the Wii console freezes in the main menu screen.
Try the Wii "RESET".
Here's how:
1. Unplug the Wii for at least 5 minutes.
2. Plug it back in.
Dec 27, 2008 | Nintendo Wii Console
Ps3 freezes before getting to main menu!!
Try Accessing the Ps3 Recovery Menu
Turn off Ps3
Once the system has been shutdown, re-press your finger until you hear 2 consecutive (quick) beeps
You will be prompted to plug in your controller via usb and then hit the ps button
The recovery menu will pop up
Recovery menu
* restart system
* restore default settings
* restore file system
*rebuild database
*restore ps3
*system update
Now I was not sure which one to choose. I clicked restart system and that did NOT work so I clicked restore ps3 and lost everything but it DEFINITELY WORKED!!
Nov 02, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
78 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
