My unit will stop working after 20 minutes.
at the beginning it stop playing any sound and eventually it get turned off.
since it is related to time, I presume that it might have to do with unit gets heat and requires cooling off.
please advice asap.
thanks,
Lior
Hi Liorpe,
It is possible the Laser is not sliding all the way up and down its rails. Lint , dust, screws sometimes get in the way of the lasers travel to completely read a disc. They do start at the center of the disc and read outward. Sounds like if it will do 20 minutes or so and then quit, its not a heat problem so much as your laser has only 20 minutes of dvd play travel on it rails before it gets stuck. Seen it bunch.
the unit works well when the POWER swich is turned ON, however after about 8-10 minutes, it stops working. I'm not even able to turn the power ON again as the POWER ON button on the DVD does not respond. I than have to switch off the car, take out the keys, and re start the car and than turn ON the car dvd and than it starts working and than again stops after about 8-10 minutes. It be either a radio or a cd that is being played in the dvd unit.
