Question about Whirlpool Dryers
Dryer not heating clothes.I WOULD LIKE TO KNOW IF THERE IS A RESET BUTTON .THANKS ED.
  • Whirlpool Master
  • 8,220 Answers
Ed take a gander at these sublime repair pix
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 28, 2009
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
Jan 25, 2016 | Dryers
Tumble dryer wont dry clothes reset button doesnt work
Check the Circuit Breaker. It is a double Breaker Switch. one side is for the heat one for the motor. If that is good then it's possibly the Heating Element or one of the two heat sensors.
Jan 17, 2013 | Dryers
LG DLe0442W Dryer working but no heat at all.
Check the heating element. That is were the fault is coming from.
Jan 09, 2012 | LG DLE2532W Electric Dryer
My clothes are longer getting dry in my dryer. Is there are a reset button that I accidentallly touched
Hi, No reset button to touch...
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 19, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Stops before clothes are dry
Sounds like a motor going out . You need to replace the motor .
Jun 29, 2010 | Kenmore 65924 Electric Dryer
Hoover Tumble Dryer trips out
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Whenever this fuse goes bad it'll either trip the circuit breaker or the dryer wont heat. You can also check it for continuity with an ohm meter, no continuity means the fuse is bad and you need to replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Hoover HW5 513M Front Load Washer / Dryer
Dryer not getting clothes dry
this will most likely be a problem with the heating element or a thermal cutout which are usually located on or around the element.some makes have cutouts with a reset button whitch when pressed will restore heat.
Nov 05, 2008 | Dryers
Dryer does not dry clothes
On the top of the heater box there is a thermal fuse that blows if the dryer overheats, on this model it could occur if the air circulation fan is faulty, or the condenser valve is faulty, alternatively the sump hose filter may be blocked, only a closer inspection of these items will determin which the problem is.
Regards
Advisor
Nov 13, 2007 | Hotpoint Aquarius WF000 Front Load Washer
LG DLG 5988B gas dryer not heating
HELLO:
Have you looked at the over heat sensor on the left hand bottom of the burner pipe?
I found this and with a simple test with a butane lighter.
I used a cheep Digital volt meter and set it to ohms.
The sensor was open meanning that their was no connection between the terminals.
On the rear of this sensor there is a small button.
When I pushed the button I hear it click and the switch closed up.
I reinstalled it and the machine work perfect.
I think this is a fail safe if the exaust flue becomes clogged.
Otherwise why would it have a re-set button on it?
I am not a service / repair person.
Unplug the unit before you take the lid and front cover off.
the burner unit is in the lower right hand corner as you face the dryer.
The top comes off first and then the control panel and then you can remove the door and fron panel to expose the blower and burner.
Be carful and good luck.
Uncle Ed.
Nov 05, 2007 | LG DLG5988 Gas Dryer
Dryers Logo
85 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
