Question about Sony PS-LX250H Turntable
The belt fell of the gears on my turntable.
The belt came off and i don't know the path you're suposed to put it back on.
    Scholar:
  • 113 Answers
Hi dont know the model but normally like so:
Take the platter of the turntable, it should just lift of, but there could be a circlip in the middle that needs to come off first. Just lift the mat first.
Place the belt back onto the platter first, should see where it goes, then put the platter back on. There are holes in the paltter which you can then grab the belt and pull it over the motor spindle.
Hope that helps
Posted on Jul 28, 2009
How do I put on a sabre 1542 hydr belt
Hydro static drive belt path. View second if gear style transmission.
Gear Trans drive belt path.
Oct 16, 2014 | Garden
Need help putting on my radio
you wasnt suposed to.cut the wire what you was need to do is go to radio.shack,walmart or best buy and get a thing its call wiring harness adapter and look.for the right one that fits your car by year and model hope this helps 7_17_2013_2_19_43_am.jpg
Jul 02, 2013 | Car Audio & Video
How to put a belt on
You put a 3/8" ratchet in the tensioner arm. Looking at the side of the engine to the passenger side of the van, the tensioner is at the top of the engine towards the back. Twist the tensioner to allow the old belt to be removed, Install the new belt following the same path. There should be a sticker on the belt guard by the power steering pump. The belt will fit smoothly on all the pulleys. Pay attentions as some pulleys have the belt groves facing in, some have the belt groves facing out.
IMPORTANT - When you do this, put all the keys for the car in your pocket so no one can try to start it.
Oct 18, 2012 | 1999 Pontiac Montana
2002 mazda millenia 2.5 v6 just replaced timing belt that was broken...double and triple checked t belt alignment is correct put it all back together....now no start...compression is 50% suposed to...
Can stop cranking. With compression figures that low, it will never start. Are you sure the figures are accurate? Throttle wide open when cranking up pressure? Compression has to be at least 100 psi for the spark to ignite the mixture.
If the belt broke while engine was running, and if it is an interference engine, you may have sustained some bent valves, internal damage to one or more cylinders, but not, I don't think, to all cylinders. I don't understand how you are getting such low compression on all cylinders Those figures sound like both head gaskets are failed, or the timing is way off.
Review your timing procedure and recheck compression. Something is definitely wrong. Hope you can figure it out. Good luck.
May 31, 2012 | Mazda Millenia Cars & Trucks
How do I loosen the belt for the power steering and alternator? What bolts need to be loosened etc.?
There is a belt tensioner somewhere in the loop that the serpentine belt travels. Look for a pulley that is not running anything (like the power steering, alternator, etc). Either in the center of that pulley or on the arm that the pulley is attached to will be a square hole that is the same size as the square peg in a 1/2" Ratchet. Put the ratchet in the hole and have in the loosen position and then pull. That will loosen the tensioner releasing the tension on the belt enough to get it off. Take note of the path of the belt so you know how to put it back on when you are putting it back together.
Good Luck
Dec 19, 2009 | 1996 Nissan Sentra
Belt on my 19tdi has snapped and i dont know the path
if its a supertine belt the digram is shown under the hood look arround find the pitcure if just reg belt u may or may not haft to remove the other ones to get it on like say if its in the back pulley its got to bee in line with the pully on the moter u should have a slide arm on the alt with about an 1/2 eanch bolt loosen that the alt will give just enuif to get it off put back same way u take off a#1 in tn
Apr 04, 2009 | 1997 Volkswagen Passat
Need to Know how to replace belt on 07 jeep Liberty. Cat was under hood when I started and knocked belt off. Need to Know how to put belt back on.
serpentine belt requires a wrench (prybar) on the tensioner.
Re install the belt & release tension from prybar.
There is a diagram on the radiator supprt telling of the belt path.
Dec 25, 2008 | 2007 Jeep Liberty Sport
I have a 1999 pontiac montana van with a v6 how long does the timing belt last the van has 100,000 miles should I be concerned about the timing belt?
HI.....
On your PONTIAC MONTANA,
You don;t have to WORRY about the timing belt.
Because your have use a TIMING CHAIN.
And is suposed to be good for the life of the engine.
But you can replace, if you Know that is bad, making grinning noise,.
But DON'T for maintenance.
Is very small. that mean Hard to come damaged.
I hope this information work for you. and resolve your question.
Thank you for use fixya.
Jul 16, 2008 | Pontiac Montana SV6 Cars & Trucks
ALTERNATOR BELT
can be done manually, and go to autozone.com you might find some information for the belt
May 27, 2008 | 1988 Ford Taurus
Sony PS-LX250H Turntable Logo
185 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
