Question about Cameras
Hi, my digital video camera has RCA video output only, my monitor has VGA and HDMI inputs, how can I get my camera to work with my monitor ? Thanks Drew.
    Brigadier General:
  • 4,090 Answers
There are conversion plugs sockets from RCA to VGA RCA in VGA OUT Contact an electronics store
Posted on Jul 27, 2009
Can i use my tv as a monitor for my home computer (Dell Optiplex 745)and if so how. I tried difrent ways and cant seam to do it.Help. Please. Chris.
The TV should have VGA input socket to connect with. if have; you can connect the TV with the computer, using a VGA to VGA cable.
VGA input socket.
VGA - VGA cable
25737496-zeccwmaoed3oumaueic5tnov-2-2.jpg http://electronicshelponline.blogspot.com/
Jun 09, 2015 | RCA Televison & Video
How can I make a NEC Plasma Monitor that was given to me work like a TV that has AUDIO?
If it has no internal sound, then you obviously can't make it function like a TV aside from the picture right? It does have inputs whether HDMI or standard Cable wiring to see TV from a cable box?
You'd need to have RCA cables coming from the cable box (Audio out - white wire I'd figure) going into a stereo near the monitor that has a VIDEO button on it where the white RCA cable is plugged into the Audio In jack.
A stereo receiver or even old sort of stereo with a Video or Auxillary sort of jack with button to activate that jack will allow for surround sound from the stereo coming from the cable box in sync with the video of the TV.
Feb 08, 2015 | NEC PlasmaSync PX-42VP5A 42 in. HDTV-Ready...
I have HDMI laptop and Dell 1706FPVT 17" VGA monitor. I have VGA to HDMI cable and I connected the cable between these two machines but it is not working. Solution, please.
First of, a little bit of explanation.
VGA = analogue
HDMI = digital
The answer seems to be in your question.
it reads "VGA to HDMI". These cables or adapters doesn't work the other way around. I am guessing your cable can only support vga output to HDMI input. And your setup is HDMI output from your computer to vga input to your monitor.
Solution:
Try and find HDMI to VGA cable or adapter. This is expensive.
If your computer has a vga output, use this with vga to vga. You won't get a better resolution by using HDMI to vga.
Or are you stuck with only HDMI output?
There are adapters for USB to VGA too. This could be less expensive. I have one for my friends Apple Air. I am not a "i" fan so I do not have much experience on Apple.
Hope this helps.
May 04, 2014 | Dell 1706FPVT 17" LCD Monitor
I would like to hook up my old monitor, product LT782s, model 700P, to my new monitor so I can have duel monitors. The cord has 2 screws to attach. The new monitor does not have any place for a "scr
You need to connect both monitors to a computer. Monitors do not daisy-chain (in general). The exception are some SCART-enabled monitors.
What is your source (desktop)? What is the make/model of your new monitor? Please add a comment with the video outputs/inputs for your source and second monitor.
Many newer desktops have two or three outputs. (Some video cards have display port outputs which with active adapters can support 2 monitors each.)
If your computer has two or more outputs and your new monitor has an input compatible with the extra output, get the appropriate DVI, DVI-HDMI or HDMI cable for your new monitor. See the next section if both monitors have VGA input.
If you have a desktop with only one video output, you may be able add a video card to support two monitors. (Depending on your computer, you may need to upgrade the power supply to support a video card.) Then get the appropriate adapter or cables to add the second monitor. (Note: if both of your monitors have only VGA inputs, check the specs for video cards carefully. Not all modern cards support analog outputs on their DVI, HDMI or Display Port connections. These digital outputs would require a digital to analog converter to give the VGA out.) However, if one of your monitors will accept DVI digital signals and the other VGA, add a card with one of each of these connections and a DVI cable to match. (This is an if needed extra; many monitors still ship with only a VGA cable.)
Then turn off your computer, open it and add the video card. Install the drivers with only one monitor attached. Then power down the computer and connect the second monitor. Turn on both monitors before turning on the computer again. Most of the time, the second monitor should be recognized (by Windows) and the appropriate refresh rate and resolution chosen. If not, you may need to enter the Display settings to set the monitor up.
I have seen some computers/video cards where only one output is initially enabled. You may have to go into the device settings to enable it. (Laptops often need their external video ports enabled in the BIOS.) Bad video ports/cards/cables do happen so RMA if needed.
The USB video adapter, http://www.newegg.com/Product/Product.aspx?Item=N82E16812225007 , can be added to a desktop to give a second VGA output but it isn't the best solution. USB bandwidth limits are significantly lower than those for a PCIe x16 slot or an old AGP slot.
I hope this helps. Please add more information about your system if you want more assistance with this problem.
(who has done dual monitors with older and newer computers. My old Pentium 4 with a Radeon x1350 video card was fine for driving a VGA monitor and an HDMI monitor (using a DVI to HDMI cable). My second generation i5 and P8Z68 motherboard system is also fine using the on-CPU video graphics for those same monitors. A video card would improve gaming but isn't required.)
Dec 13, 2012 | Computers & Internet
How to use my HDTV for a monitor for my computer
What video output connection type do you have on your PC.....DVI, VGA, S-VIDEO, HDMI?
What video inputs connection types do you have on your HDTV.....DVI, VGA, S-VIDEO, HDMI?
The cable you need will be whatever connection you have....ie: DVI----->HDMI or VGA----->VGA or DVI to DVI.
You will also need an audio cable, 2 Phono RCA Red/White (Left and right) -------------> audio output jack plug or Optical in------->Optical out
Thanks
Sep 05, 2009 | E-Machines eMachines Desktop PC
Use TV as external monitor from laptop
no tube tv won't mirror monitor. needs vga connection at the back of tv.go to store have a look at lcd or plasma screen.the card is ok.
Jun 26, 2009 | HP Pavilion DV6500Z Notebook
Connect to a tube TV
hi mr. pavilion dv6700z. i have the same problem before but after i tried and use my genius mind. i made it. and the television is working in my laptop as a external monitor. pixel is good. just connect in card video out to video iput to television. romsky79@yahoo.com.
Jun 06, 2009 | HP Pavilion DV6700Z Notebook
Help
Step 1
Shutdown your computer and look at the rear of the case to determine the type of video connections that your machine has. Nearly all computers will have the standard 15-pin VGA output port. In addition, you may also find that your computer has an S-video port, an RCA composite video port, a set of three component RCA video outputs or perhaps even an HDMI output port.
Step 2Determine the types of video inputs that are available on your plasma TV. There should be a standard RCA composite input, a three-jack RCA component input and an S-video input. In addition, you may also find a 15-pin VGA input, a DVI input or an HDMI input. Step 3 Select which type of connection you will use. HDMI and DVI represent the highest-quality connections, followed by VGA, Component, S-video, and composite. If your computer has only a VGA output and you will not using it solely to drive the plasma TV, you may want to invest in a video card upgrade. Most new video cards will offer dual monitor connections and possibly a separate TV connection. The first monitor connection is intended for the main computer monitor, and the second monitor connection, or the TV output, can be used for either a second monitor or a TV. Depending on the card, the TV output may be DVI, HDMI, component, S-video or composite. Step 4Purchase a video cable long enough to reach from your PC’s video output to your plasma TV. If the distance is over ten feet, you may want to invest in high-quality cables to ensure that the plasma TV receives a clean signal for the best possible picture. Cables over thirty feet in length, depending on the connection type, may result in poor video performance. Step 5Set your computer’s screen resolution to something that your plasma TV can accept, using the “Display” settings in the “Control Panel” in Windows. Refer to the owner’s manual of your plasma TV for the supported resolution and refresh rate. If you are using the S-video, composite or component outputs on your computer, this step may not be necessary. Step 6Connect your PC to your plasma TV using the appropriate cable. Start the computer up and it should recognize the attached display. In the “Display” settings, you will need to configure how the plasma TV is used if it is attached a second display. Most video cards support “Clone” or “Mirror” mode, which displays the same content on both displays. In addition, there is the “Extended” mode, where the second display will operate independently, and windows can be dragged from one screen to the other. If your plasma TV is the only monitor for the computer, you will not to configure the multiple display modes. Step 7Connect a cable from the sound output of your PC to your plasma TV using the appropriate audio adapters. Then relax on the couch and enjoy your videos on the big screen.
Aug 09, 2008 | Computers & Internet
Tv/pc
Your Panasonic TC-26LX20 26 will only allow video inputs through the:
1. composite video/audio input ( RCA phono x 3 ) - front or rear
2. S-Video input ( 4 pin mini-DIN ) - front or rear
3. component video input ( RCA phono x 3 ) - rear
4. HDMI ( 19 pin HDMI Type A ) - rear
Depending on the output(s) available from your PC, you can use any of the following:
a. the yellow RCA female
b. S-Video output ( 4 pin mini-DIN )
c. VGA (which normally goes to the monitor) but would require a VGA/HD to HDMI Format Converter such as the one here
Should this be not enough information, please post back with what PC brand/model that you have. Additionally please specify what Video Card are you using if your PC is a desktop.
Good luck and kind regards.
Nov 17, 2007 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
Cameras Logo
53 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
