How do I replace the dogs in the adjatator - Washing Machines
  • 5,911 Answers
The following link explains the steps necessary to replace the agitator dogs:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
If you have questions about this repair, or require additional assistance, please let me know.
NOTE: The part number is included in the instructions I provided. If you haven't purchased the dogs yet, appliancepartspros.com carries them for about $5.
I hope you find this information helpful.
Posted on Jul 27, 2009
My kenmore portable washer fill up with water but wont keed adjating
no agitation? check the door switch, the motor coupler, the clutch and the belt if applicable and may even want to check the cam dogs in agitator
Feb 07, 2015 | Kenmore Washing Machines
How do you remove adjatator on compact Sears 11044182400
in the hub and down the agitator about 10 inches down there is a 7/16 bolt has to be removed and then u can remove the agitator top to get to the cam dogs, but to remove the complete agitator u may need a special tool if u dont have one u can try using a rope wedged underneath the agitator and a hard pull upwards. can use a pc of wood to pry it.
Nov 01, 2014 | Kenmore Washing Machines
I am having problems with my adjatator and I don't see what I should see (the dogs)
That model of washer does not have agitator dogs. the agitator drives directly from the drive shaft and does not ratchet like Whirlpool top load washers do.
Aug 27, 2013 | Maytag PAV2300 Top Load Washer
The adjatator wont really turn to good how do i fix it
Had same problem with mine. useing a nut driver remove the bolt that is reached from the top of the agitator. The plastic teeth parts are called dog agits (not sure on that spelling) once the bolt is removed place the agitator on the floor and put your feet over the sides of the bottom section then you should be able to pull off the top section and will take a bit of force to do that. You will need your make and model of washer to get the dog agits and they aren't very expensive at all!! then of course put back together but make sure the top section is completely attatched to the bottom all the way so there won't be any extra space that wasn't there before!
Feb 07, 2013 | Whirlpool Washing Machines
Why does my washer make soo much noise when washing sheets??and the sheets wind up in a big ball
If the mod # begins with 110 its whirlpool built. Check to see if the top part of adjatator is moving grab the top of it turn back and forth it should turn the lower section in one direction but not the other.If it is not doing that and just spinning freely then your dogs are defective. cheap part and easy to replace do the test and get back for more info......Thanks for voting
Mar 20, 2011 | Whirlpool Washing Machines
Agitator seems "broken" in half.
You will need a set of adjatator dogs about 5.00 for a set..get them and we will show you how to replace.czerney@msn.com thanks for voting good luck.
Mar 15, 2011 | Whirlpool Washing Machines
Hi, I have a Kenmore 110.26832692, lately it's been making a loud grinding/thumping noise when agitating. The clothes end up wrapped around the agitator, sometimes even stuck underneath it. The basket...
Sounds like maybe the changing of the dogs might be the problem./The top section of your adjatator sould move freely one direction turn it the other way bottom section should move with it. If it does not do that then your dog install got messed up also you should not barely get fingers under botton section of adjatator/ Note the basket is not supposed to move when washing on this unit . see if unit is doing any of those things get back to us...Good luck
Feb 09, 2011 | Kenmore Washing Machines
Kitchenaid washer top load will not adjatate or spin
Bad/broken coupler connects the motor to the gearcase.
Mar 07, 2009 | KitchenAid KAWS850LE Top Load Washer
GE WJSR2070B won't agitate
There is a drive block under your adjator. You must pull the adjator off. Get your fingers ( Man Friend LOL ) under edge of adjator & pull. You will see a plastic pat with screw in it . if you can spin with hand , replace it .
Mar 01, 2009 | GE WJSR2070B Top Load Washer
Whirlpool Thin Twin Washer
Sounds like the transmission is gone the thing you call the spinning mechanism is call the adjatator it should move left to right I can tell you right now to replace the dog ears if it is a kenmore washer they go bad all the time they cost about 5 dollars they are under the cap on top of the adjatator you will need to pull it off to do the job good luck Ron
Jun 10, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
