Question about Grilling
Turn smoker on it pops breaker, what could be the cause?
    Top Expert:
  • 12,744 Answers
A short in system somewhere use meter to test components and wiring
Posted on Aug 19, 2017
My hot tub trips the GFCI. THe GFCI holds when I disconnect the wires running into the hot tub. I have disconnected EVERYTHING from the circuit board including the heater and the GFCI still trips.
Sounds like wet or bad wiring somewhere but u should do a visual inspection of all the wires & connections first then through process of elimination. Turn off breaker disconnect all wires and connect one wire then turn breaker on & if it dosent pop the. Turn it off and connect one more wire and turn the breaker on & continue until you get the breaker to pop and the last wire or board u just connected is your problem & go from there.
Feb 14, 2016 | Pool & Spa
Cajun injector electric smoker stopped working
Check for power at your outlet; a tripped GFI or a tripped breaker in your panel box may be the cause if the outlet is dead. If the outlet is good then you know it is the electric smoker.
Nov 27, 2014 | Cajun Injector Double-Door Xl Electric...
Smoker throws breaker
Larger breaker.... Or split breaker....what size right now??
Nov 19, 2012 | Masterbuilt 20070106 Electric Smoker
Eeaf smoker keeps tripping off
Hi sally mako...
Make sure your breaker is strong enough to handle the ampreage draw of the smoker element.
Try a different receptical with a known larger breaker...
If still kicks the breaker, then remove the electric plug from the receptical and check all connections on the element and controls to make sure they are not corroded or broken and shorting out.
Please take time to rate me
Sep 24, 2011 | Masterbuilt 20070106 Electric Smoker
My furnace will not turn on it is a intertherm feh 015ha. Every time I turn on the breaker the fuse pops really loud in the furnace and turns it off again. How can I figure out what is wrong if I cant even...
I would suspect your evaporative motor (located in the furnace) is shorted.
To prove it - just disconnect the electrical wires to the motor and turn the breaker back on.
Most likely the breaker will stay on - which will tell you for sure that the motor is shorted.
Note: it's possible that the capacitor on your motor is shorted - but I doubt it. i would bet on the motor. In any event - you have a 'direct short' which is causing your breaker to pop, and I would bet it's the motor.
If it isn't the motor you will just need to find the 'short' to keep the breaker from popping.
Aug 06, 2011 | Heating & Cooling
Grill will not turn on
I assume you are referring to the auger motor. If so, have you checked the electric receptacle the g=auger motor is plugged into? Plug another electric appliance, like a lamp into the receptacle to see if the lamp works. If not, look for a tripped circuit breaker in your home's breaker panel. If one is tripped, make sure nothing is plugged into the offending receptacle and reset the breaker. Plug the auger motor back in to see if the breaker trips again. If does, there's an electrical issue with the auger motor or the cord.
If none of the above is the problem, i have included a link to Traeger Industries website. There you can find and download the Owners Manual for your Grill-Smoker, which also has a Trouble Shooting Section.
Feb 21, 2011 | Traeger Industries BBQ070 All-in-One Grill...
Pops circuit breaker when heating
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
Mar 14, 2010 | Masterbuilt ESBMPG Grill
Electric smoker is now tripping GFCI breaker
GFCI breaker tend to wearout and become more sensitive after time and use. Motor loads are especially hard on them. Also resistance loads such as heating elements. Your smoker may be pulling a bit more electric than it used too.
Check the power draw of the smoker when operating, if it is high then fuigure out why. It it is normal then replace the braker. Use a regular breaker if the GFCI is not required, or run a cord from an outlet that is not on a GFCI breaker.
Jan 24, 2010 | Masterbuilt 20070106 Electric Smoker
Grilling Logo
197 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
