Question about Sewing Machines
I have a slow drip coming out of a screw hole on a bracket that runs on the bottom back side of the dishwasher the bracket has four screws on it it is a quiet partner I model# du10050xtps1 serial# fr4203945
  • 1 more comment
  • dannyott18 Jul 27, 2009
    i have found the leak what i dont know is how its coming from there i also bought the whole motor and pump assembally but dont want to use it if i dont have to what i want to know is what that bracket is for and how water is coming out of that hole
  • dannyott18 Jul 28, 2009
    its a du1050xtps1 i hit two many zeros do i need two turn the washer lon its front
    found the problem its the tub. there's a bracket on the bottom backside of the dishwasher, it has four screws screwing into the underside of the tub. where the screw goes is attached to the tub, it has worn thin and is causing the leak. they dont show this metal bracket on the diagram but it runs on the backside under the motor and wher the heating coil comes down. have know idea what it does
    Top Expert:
  • Sewing Machines Master
  • 75,822 Answers
The washer water basin is leaking, u will need to get the seals replaced
Posted on Jul 28, 2009
  • 19,396 Answers
Hi, the model a you gave did not return any apppliance. Here the schematics for DU1000 undercounter series.
The braket at the back is probably dripping because of a leak through the drain hose. The drain hose starts from pump assembly , where it is attached, check it out to find the leak.
  • 10,865 Answers
Hi. I can help you. Begin by shutting off all of the water leading to the dishwasher. Then open the door and put a fan near the opening. Your goal is to totally dry out everything. Once that is achieved turn the water back on and see where the water is leaking, Now you have isolated the leak and you can go ahead and fix it. If you need more help get back.
Posted on Jul 27, 2009
Repairing a Singer Sewing machine presser foot lifter.
Inside the foot the wires are connected to two different screws. They are obviously coming loose by being pulled.
1. Open the foot on the bottom.
2. Look where the screws are. You need to have the wires connected there.
3. Before connecting to screws: tie a knot in the wire from the inside of the foot pedal where the wire protrudes through the hole.
4. Now, tightly connect the wire to each screw. Apply bottom of bracket. Now, sew!!!!!!!!!!
Sep 23, 2016 | Singer Sewing Machines
I have a SINGER ingenuity Sewing Machine I want to put it into my SINGER SEWING MACHINE DESK MODERN OAK CABINET 201 15-91 115 306 319 27 66
1. Find two holes on the back side of the machine towards the very bottom of the machine. Small screws are inserted that need to be almost removed.
2. There are small pegs attached to two hinges (towards back of table where opening is). Stand them up towards the ceiling. (Possibly need help)
3. The sewing machine will face the front of the machine towards the floor and the bottom of the machine towards yourself. It must be held while doing this.
4. Aim the holes of the machine towards the holes and lower the machine. As the pegs go through the holes of the sewing machine the screws need to be tightened.
Sep 21, 2015 | Singer Sewing Machines
How do you open the electronic foot pedal for the Bernina 1630?
The foot control function for a motor run condition is variable from 4k ohms to 0 ohms with full depression of the foot control top plate. Heeling back on this control makes a 10k ohms signal for needle down function.
To remove the top cover, peel back the vinyl top covering to expose a single hole above each of the two plastic axle or hinge pins located on each side of the top cover. Insert a pin punch (or other tool)
appropriate in size through the hole, placing the pin end against the hinge pin and pry/pop out the hinge pin. Pull out the hinge pins and remove the cover. Reverse the process to assemble the cover. To insert the barbed vinyl projections on the bottom side of the vinyl top covering, moisten the projections with a little KY jelly and reinsert into the holes in the top plate.
http://www.sewtechnical.com/
May 27, 2015 | Bernina Sewing Machines
Needle clamp tragedu
The needle clamp usually has a screw on the back that is tightened to prevent the needle holder from falling off. The screw on the back should be very loose. Place the holder on the arm (moves when you rotate the wheel by hand) with the screw towards the back and the hand screw on the side. Tighten the screw in the back and it shouldn't come off. Now, place the wire on the side where the hand screw on the inside of the hole along with the arm and place your needle in. Now you can tighten.
Apr 27, 2013 | Sewing Machines
Last year I changed the machine engine (PfaFF 1222 E). I noticed immediately that the machine sewed too slow and I thought it was a problem of the kind of engine the repairer had put into the machine. But...
If the machine did sew fast the the replacement motor, then the problem might be that the machine is getting gummed up somewhere. Pull off the top cover, remove the 5 screws from the bottom of the base plate, (4 large screws, 1 small screw), remove the base plate remove the 1 screw from the bottom of the free arm cover. Now you can see most of the moving parts. Spray a little WD 40 on all the areas that you see metal to metal rubbing together, both on the bottom side of the machine and the top side. Don't flood the machine and stay away from the motor area. Plug the machine in, lay it on it's back and run it full speed, or at least till it runs full speed. After you free it up, blow out the machine with compressed air, and reoil with tri flow all the areas again. Run the machine again, and you've started your own tail gate repair shop.
May 05, 2011 | PfaFF Sewing Machines
Singer 328k bobbin winder replacement
Follow these instructions, undo the 2 screws on the right hand side plate where the balance wheel is and take the plate off, undo the screw on the chrome stop motion wheel, undo the stop motion and take it off, take off the 2 pronged washer and notice which way it goes on, not a problem if you can't remember, you should be able to pull the balance wheel back so you can get to the screws on the winder, if you can.t and if you have a problem getting the balance wheel all the way then go the very bottom of the machine and you will see 2 big holes and one of the holes will lead you to a big screw and nylon adjuster, slacken the screw and move the nylon adjust so the belt goes slack, you can not take the balance wheel all the way off to get to the screws on the winder, take the old one off and screw the new one on, whilst you have the balance wheel off it would be wise to put some thin oil on the shaft before you put the balance wheel back on, when you have the balance wheel on and the and the belt round the pulley turn the nylon adjuster so the belt is tight and tighten up the screw, put the side plate back on, put the 3 pronged washer back on, put the stop motion wheel back on and just tighten finger tight then tighten the small screw.
Nov 22, 2009 | Singer Sewing Machines
WHERE IS THE FUSE FOR THE JANOME MEMORY CRAFT 9000? THANK YOU
Remove the top cover by taking the two large screws and the small one under the handle, LHS.
Remove the left side cover. The hidden screw is a 2.5mm allen accessed through the vent.
Lay the machine on its back and remove the four large phillips screws on the bottom and the small screw for the side, paying extreme caution with respect to the embroidery arm.
CAREFULLY move the bottom to the left and out of the way.
Inside the body of the machine you will see a black box held in place by three or torx/slotted screws. Remove the screws and, as you slowly pull the box out MAKE NOTE OF WHICH WIRES PLUG IN WHERE.
Jul 11, 2009 | Janome Memory Craft 9000 Computerized...
Thread getting stuck
We had he same problem with no solutions posted. Solution: First, make sure the bobbin case is clean. Ours was slightly rusted. The rust acted like a fine sand paper keeping the thread from encircling the bobbin. We used an metal cleaning powder to remove it. we also noticed that the entire bobbin area of the machine was dirty and had oxidation on the metal. We cleaned that as well.
Second, we checked the hook's action. (We took off the ring around the bobbin and removed the bobbin case as well. we left the hook in the machine and then turned the machine. We watched for how well the hook grabbed the thread from the needle.) We noticed that the hook was slightly slow and was not grabbing the thread. The hole in the needle was slightly above the hook as the needle retreated and hook spun around.
To repair this, we took off the front plastic cover (the side facing the operator). There are screws on both sides of the machine for this. After the cover is removed, you will notice a flat bar going from top to bottom about 1/3 from the right of the machine. This bar has four screws. This bar is the timing adjustment for the bobbin hook. Loosen all four screws. If you turn the bobbin by hand, you will see the bar flex back and forth. Turn the bobbin all the way to the right and tighten the screws. The hook should now catch the thread properly.
Aug 25, 2008 | Brother LS-1217 Mechanical Sewing Machine
Loose end cap cover.
This actually applies to most of the newer Pfaff machine models:
  1. If the cover will come completely off, look at the inside of it to make sure the bracket that holds it in place is not broken. If it's not broken...
  2. Grab a flashlight
  3. Remove the stitch lid - there are little silver clips at the base of the lid on either side - push the lid either to the left or right against these clips and you'll be able to pop it right off. You will reverse procedure to put it back on. Removing the lid isn't absolutely necessary but does make it easier to see/access screw.
  4. Raise the handle of the machine
  5. Aim your flashlight into the machine behind the left side of the handle... you should be able to see down inside the machine to the set-screw that holds the side cover in place
  6. Check to see what kind of screwdriver you need - either a Phillips head or a Torx Driver. Most of the newer Pfaff models require a Torx Driver (this is a star-shaped screw-driver available at most hardware stores - Size T25 should fit this particular screw)
  7. Slide cover back into place - may need to wiggle it a bit to get the bracket under the screw
  8. Tighten screw & you should be back in business
If the bracket on the inside of the cover is broken, this part will need to be replaced. Pfaff parts are only available through an authorized Pfaff dealer so your local dealer will need to order it for you.
Hope this helps - please don't hesitate to respond if you need further help or clarification.
Happy sewing,
Kim & Linnette
Dec 20, 2007 | PfaFF Tiptronic 2030
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
